29422 Discussions
Assistance Required: "Catastrophic error"
Caleb_Parker
I am trying to compile about 200 .f90 source code files into a standard .exe file. I have been given a specific set of flags to use in Intel Visual Fortran XE.
Fortran flags:
/nologo /debug:minimal /O1 /Oy- /assume:buffered_io /fpscomp:nolibs /Qzero /fpe:0 /fp:strict /Qfp-speculation=off /names:lowercase /module:"Release\\\\" /object:"Release\\\\" /traceback /check:uninit /libs:static /threads /4Yportlib /c
Additional Fortran flags:
/assume:protect-parens /Qprec-div /Qprec-sqrt
Linker flags:
/OUT:"Release\\EnergyPlus.exe" /INCREMENTAL:NO /NOLOGO /MANIFEST /MANIFESTFILE:"i_removed_this_path_for_posting\\EnergyPlus.exe.intermediate.manifest" /MANIFESTUAC:NO /SUBSYSTEM:CONSOLE /IMPLIB:"i_removed_this_path_for_posting\\Release\\EnergyPlus.lib"
Only two files create errors. In the error list it says "Compilation Aborted (code 1)."
In the BuildLog, it gives the following message:
"0_12459
: catastrophic error: **Internal compiler error: internal abort**
Please report this error along with the circumstances in which it
occurred in a Software Problem Report. Note: File and line given may
not be explicit cause of this error."
PlantGroundHeatExchangers.f90
PlantSurfaceGroundHeatExchanger.f90
The two files are attached.
Any information would be greatly appreciated.
Thank you!
In order to investigate this, we would need the sources to all the modules used by these two files. Can you attach a ZIP of the project or of the necessary modules?
Which specific compiler version are you using? (It will say at the beginning of the build log.) If you switch to a Debug build, do all the sources compile successfully? (Don't worry about linking.)
