29653 Discussions
Associate construct with selector having a pointer
Martin1
Consider the following code
program assoc_ptr
   integer, pointer :: p, q, r
   allocate(p)
   allocate(q)
   p = 1
   q = 2
   associate(x => p, y => q)
      print *, x, y
      q => p
      y = 5
      q = 6
      print *, x, y
      allocate(r)
      deallocate(p)
      p => r
      x = 3
      p = 4
      print *, x, y
   end associate
end program assoc_ptr
Is this allowed and standard-conformant? My gut-feeling is that this is simply wrong code. With ifort (19 beta, with and without optimisation) the output is:
           1           2
           6           5
           3           5
So in both cases, the association of y with q and of x with p are lost. In general this should lead to a SEGFAULT in more complex cases. Nevertheless, this looks like a bad pitfall if pointers are buried within complex derived types whose components might be reallocated in some subroutines...
Juergen_R_R
Valued Contributor II
Yes, this is tricky, but the association is not lost. When you print out x and y, you print out the target of the pointer. The target of the pointer x in the final step is 3 because of the statement x = 3 above, and the target of y has not changed from 5 since line 14.
Steve_Lionel
In this example, x and y are not pointers. Associate names do not have the pointer attribute. The wording on this has changed a bit from F2008 to make it clearer, so I will quote from the F2018 draft:
The associating entity does not have the ALLOCATABLE or POINTER attributes; it has the TARGET attribute if and only if the selector is a variable and has either the TARGET or POINTER attribute.
Martin1
I am not sure whether I understand you correctly. In my opinion x is still associated with what p has been before it was reallocated, but this is lost. So with x=3 I write into an illegal memory address.
Anyway, in the past I have used pointers and was not happy with this kind of pitfalls. But pointers are kind of dangerous. Now that I can use associate, I was hoping that such mistake are not possible, or at least can be recognised at compile-time. But it looks like, even so x and y are not pointers, that it seems best to still think of them as pointers. Probably they are implemented that way (with temporaries if association is with an expression.
Steve_Lionel
No, they are not pointers.
Martin1
That's what I wrote. But in some respect, which are relevant in the context of my short example, it becomes visible that internally they are implemented by pointers and behave somewhat like pointers. So without thinking of them as pointers it might become difficult to understand what's going wrong in cases like the code sample above. So, is there a way to avoid (or at least easily find) this kind of bug?
Steve_Lionel
Ok, I see what you're getting at. Essentially this is the same as having two pointers to an object, deallocating one pointer and referencing the other. When the first is deallocated, the second one becomes undefined (by the language rules), but there's no obvious way in Intel Fortran to detect this.
