Auto-outlining chokes on read 5, x(i)%test
martenjan
I have some outlining troubles in a big project, which I reduced to the example provided in the screenshots that I pasted in Auto_Outlining.png.
Basically, the outlining fails for the statement read 5, x(i)%test.
It works properly for the statements write 5, x(i)%test; read 5, x%test; read 5,x(i).
Is this a known problem? Is there a solution? Thanks for answering.
Steven_L_Intel1
It's not that simple - I can get the outlining to not outline the DO with the source in your fourth example. (I do wish, though, that you had attached the actual sources - would have saved me some time retyping them.) I will pass this on to the developers and ask them to investigate.
martenjan
Thanks for your rapid response, and apologies for not including my source. Ironically, the source was in my mail originally, but I could not describe the problem in words, so I erased the source and added the screenshots. Anyway, I noticed that my message is sparse on more detailed information. I am using Intel(R) Visual Fortran Composer XE 2011 Update 9 Integration for Microsoft Visual Studio* 2010, 12.1.3526.2010. The About Microsoft Visual Studio window provided more information, which I pasted below for your convenience. Let me know if I can provide more information. Microsoft Visual Studio 2010 Version 10.0.40219.1 SP1Rel Microsoft .NET Framework Version 4.0.30319 SP1Rel Installed Version: Professional Microsoft Visual Basic 2010 01018-532-2002181-70888 Microsoft Visual Basic 2010 Microsoft Visual C# 2010 01018-532-2002181-70888 Microsoft Visual C# 2010 Microsoft Visual C++ 2010 01018-532-2002181-70888 Microsoft Visual C++ 2010 Microsoft Visual Studio 2010 Team Explorer 01018-532-2002181-70888 Microsoft Visual Studio 2010 Team Explorer AnkhSVN - Subversion Support for Visual Studio 2.4.11610.27 AnkhSVN - Subversion Support for Visual Studio 2.4.11610.27 * Ankh.Package 2.4.11610.27 * Subversion 1.7.6 via SharpSvn 1.7006.2206.13750 SharpSvn is linked to: Apr 1.4.6, Apr-util 1.4.2, Cyrus Sasl 2.1.23, Neon 0.29.6, OpenSSL 1.0.1c 10 May 2012, serf 1.1.0, SQLite 3.7.12.1, Subversion 1.7.6-SharpSvn-1.7.6, ZLib 1.2.7 SharpSvn is optionally linked to: Berkeley DB 4.4.20, SharpPlink 1.7006.2206.13750 CommandingImage 1.0 This package adds the ability to change command images that was not supported in VS 2010 RTM. Crystal Reports Templates for Microsoft Visual Studio 2010 Crystal Reports Templates for Microsoft Visual Studio 2010 Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2522890) KB2522890 This hotfix is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this hotfix will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2522890. Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2529927) KB2529927 This hotfix is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this hotfix will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2529927. Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2542054) KB2542054 This hotfix is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this hotfix will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2542054. Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2548139) KB2548139 This hotfix is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this hotfix will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2548139. Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2549864) KB2549864 This hotfix is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this hotfix will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2549864. Hotfix for Microsoft Visual Studio 2010 Professional - ENU (KB2635973) KB2635973 This hotfix is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this hotfix will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2635973. Intel(R) Visual Fortran Package ID: w_fcompxe_2011.9.300 Intel(R) Visual Fortran Composer XE 2011 Update 9 Integration for Microsoft Visual Studio* 2010, 12.1.3526.2010, Copyright (C) 2002-2012 Intel Corporation * Other names and brands may be claimed as the property of others. Microsoft Visual Studio 2010 Professional - ENU Service Pack 1 (KB983509) KB983509 This service pack is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this service pack will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/983509. Security Update for Microsoft Visual Studio 2010 Professional - ENU (KB2645410) KB2645410 This security update is for Microsoft Visual Studio 2010 Professional - ENU. If you later install a more recent service pack, this security update will be uninstalled automatically. For more information, visit http://support.microsoft.com/kb/2645410.
martenjan
I found another clue to this issue. I added the dummy integer j to the code, and set it to zero, see the line j=(0) in the code below. The outlining gets correct if the closing parenthesis is present. j=0+(0) has the correct outlining too, whereas j=0 and j=(0)+0 confuse the automatic outlining. [fortran] module outlining type type_x real(8) test end type contains subroutine test() type (type_x) x(i) integer(4) i,j do i=1,10 read 5, x(i)%test j = (0) end do end subroutine end module [/fortran]
