Automaic Save of Graphics files
dick17901
When a *.bmp files is created, under "View" option, you can set and "mark" the *.bmp file just created. Under "File", you can save the file. I would like to create a sequence on instructions that would automatically do the same thing. Say if an AutoSelect was added to the menu option of View, a filename could be provided by the user, within the program, and the file could then be saved.
Where are these options storred under what module name? Or can anyone suggest a Fortran sequence that would do the same?
