Automatic array overflow
llynisa
I have been successfully calling a subroutine whose integer arguments nRange, nVal & nPtMax are used to set the size of a working array real*4 xydata(nRange*nVal*nPtMax).
All is well when nRange*nVal*nPtMax = 240,000, but when increased to 260,000 it fails with a stack overflow error.
If I set the size of the array to a constant value eg 280,000 it works perfectly. Is there a limit on automatically sized arrays?
Puzzled again
Alan
TimP
There's a limit on stack space. Increase it by appending the options /link /stack:nnnnnnnnn
llynisa
Many thanks for your prompt reply - I now realise that I should have remembered the solution, but it's been a couple of years since I had any similar problems.
Alan
I'll note that the on-disk documentation has help under "stack", and there has been a Visual Fortran Newsletter article on the same topic.
Steve
