29382 Discussions
Availability of older Intel fortran compiler versions
meyer312
Would anyone know a source for older Intel Fortran Compilers? I am looking especially for IFC 7.0. So far, I could neither find a downoad site for it, nor could I find any dealer who still sells it.
Thanks for any hints.
Purchase and register version 10.1. Then submit a request to Intel Premier Support for the older version you want. 7.0 is as far back as we can easily go.
What is your reason for wanting that particular version? You may want to try your code with 10.1 before going through the motions to get and install 7.0.
meyer312
Thanks for the advice.
The reason for wanting that particular version is, that I need to link some of my own coding into existing software, that has been compiled using ifc 7.0.
This linking did work well with ifc 8.0 under OpenSuse 9.1. After an upgrade to OpenSuse 10.3, it doesn't. Now, I do get undefined symbol errors. What I am not sure about is, whether that might be caused by ifc or the fortran-libraries shipped with the new OpenSuse. As far as I understand, ifc uses some of them?
Code compiled with ifc 7 will need to be linked with the "iepcf90" libraries provided with ifc 7. It would not link with ifc 8, which does not provide those libraries, but perhaps something else is at work.
What specifically are the undefined symbols?
meyer312
The error message says: undefined symbol: for_write_seq_lis
That should be provided in the ifort 8 and later libraries. How are you doing the link?
meyer312
The linking is initiated by the software package (Star-CD) itself, or by the user via command line. I don't know what the underlying script does in detail.
