Bad Image
dmdlog
Problem: Inability to read files.
This package contains:
Intel Visual Fortran Compiler Professional Edition 11.1.048 Update 2 Revised for Windows*
Intel Math Kernel Library 10.2 Update 2 for Windows* OS
My platform is: Intel Core2 CPU, 660 @ 2.4GHz, 1.99 GB RAM
Running Windows XP Pro. Ver. 2002 SP 3
When I try to open and read a file from a very simple program, I get the following popup:
The application or DLL C:\\Program Files\\Intel\\Compiler\\11.1\\048\\bin\\ia32_intel64\\1033\\ifcore_msg.dll is not a valid Windows image. Please check this against your installation diskette.
I could not locate this file on my installation diskette and when I closed (both) popups, I had an end of file durring readerror on the very first read attempt. The file was present in the resource directory and fully populated with the required data. I have been able to run programs without difficulty if I don't try to read a file. I recently upgraded from version 6and never encoutered this problem before.
DMDlog
DavidWhite
Valued Contributor II
You may need to wait for an Intel expert to come on line to give you a definitive answer.
However, a clue may be the ia32_intel64 folder - I run under XP SP3, and I only have bin\ia32, so I am guessingyou may need to download the ia32 only version of the compiler and try that.
David
mecej4
DLLs in the ia32_intel64 subdirectory are intended for 64-bit Windows versions. They will not run on Windows XP-32, regardless of whether or not your CPU is X64 capable (which a Core-2 CPU is).
If you are running at the command line, check why you have been put in a 64-bit environment -- you might have, without noticing it, chosen the 64-bit development environment instead of the 32-bit one.
If running in VisualStudio, choose the proper configuration (IA32).
dmdlog
Thanks! very helpful. I looked at those issues and read the release notes. The release notes suggested that I had installed the compiler in the wrong order with another application. I reinstalled the compiler and checked my use of the IA32 configuration and the problem was resolved. Much appreciated!!
dmdlog
Very helpful, your comments got me thinking in the right direction. I checked the release notes and found a problem with the compiler's installation order relative to another application. After reinstalation, the problem was resolved. Many thanks!
