29363 Discussions
Bogus standard conformance warning for compiler directives
Harald
ifort produces a standard conformance warning for code like:
[bash]subroutine bogus_warning (a, n)
  implicit none
  integer :: n
  real    :: a(n)
  integer :: j
!DIR$ IVDEP
!CDIR NODEP
  DO j = 1, n
     a(j) = 0.0
  END DO
end subroutine bogus_warning
[/bash]
% ifort ifort12-warn-on-directive.f90 -c -stand
ifort12-warn-on-directive.f90(7): warning #6477: Fortran 2003 does not allow this statement or directive.
!DIR$ IVDEP
(The intent of the compiler-dependent directives is to aid e.g. optimization or vectorization).
Note that the compiler directives in the source code have the
form of a Fortran comment and should IMHO be treated as such.
It would be nice if the warning would disappear.
Harald
We had an extensive discussion about this in the past, and decided that directives are "funny-looking statements" and not comments, and that the warnings were appropriate.
jimdempseyatthecove
Steve,
Considering that compiler directives are implementation dependent could IVF consider adding a NOWARN attribute
!DEC$ (something) NOWARN
(something else causing warning)
statement
This would satisfy both sides of the argument for/against the warning
Jim Dempsey
Well, no, that would mean thast the NOWARN directive would need a warning!
Perhaps what is needed is a "don't give standards warnings about directives" compiler option. VAX Fortran used to have several sub-qualifiers for standards warning allowing you to exclude things such as source form (tab formatting), etc. Or, simpler, separate out warnings for directives to their own message number and then you can use -diag-disable to suppress it. I will suggest this to the team.
Harald
An option to disable the particular warning would be great.
Harald
Lorri_M_Intel
Try adding the following switch to your command line:
-diag-disable 6477
-- Lorri
Harald
I am now using
-diag-disable 6477,7025
to suppress the directive-related warnings.
Harald
