29657 Discussions
Bound-type procedure using multiple interfaces
FlyingHermes
I would like to implement a derived-type with a bound-type procedure whichcan be used using different type if arguments.
I have no problem to implement this type of procedure without it being inside a derived-type.
I simply use an interface block as follow:
[fortran]Module Test
interface Get_Value
  module procedure  Get_Value_i, Get_Value_r, Get_Value_l, Get_Value_c
end interface
contains
Subroutine Get_Value_i ( Par, Val )
  implicit none
  integer      ,intent(in)  :: Par
  integer      ,intent(out) :: Val
End Subroutine
Subroutine Get_Value_r ( Par, Val )
  implicit none
  real         ,intent(in)  :: Par
End Subroutine
  implicit none
  character(*) ,intent(in)  :: Par
End Subroutine
Subroutine Get_Value_l ( Par, Val )
  implicit none
  logical      ,intent(in)  :: Par
End Subroutine
End Module[/fortran]
Calling the "Get_Value" procedure will work using any type (integer, real, character and logical) for the "Par" input argument.
Now, if this procedure is type-bound, I do not know how to implement it.
I've tried different implementations, but they all give me compilation errors.
Could someone provide me with any kind of solution for this issue.
oleglebedev
You must specify only one type-binding procedure per a PROCEDURE statement.
If I were you I code
[fortran]type, public :: foo_type
  CONTAINS
    generic, public :: Get_Value => Get_Value_i, Get_Value_r, Get_Value_l, Get_Value_c
    procedure, private :: Get_Value_i
    procedure, private :: Get_Value_r
    procedure, private :: Get_Value_c
    procedure, private :: Get_Value_l
end type foo_type[/fortran]
Best, Oleg.
What I think you want looks something like this:
type mytype
contains
procedure :: Get_Value_i,Get_Value_r,Get_Value_l,Get_Value_c
generic :: Get_Value => Get_Value_i,Get_Value_r,Get_Value_l,Get_Value_c
end type mytype
Does this help?
FlyingHermes
Thanks for your anwser.
I've tried your piece of code but it gives me the following error:
[bash]error #8259: The type bound procedure definition statement must contains only one binding name.   [GET_VALUE_R]
    procedure                           ::      Get_Value_i, Get_Value_r, Get_Value_c, Get_Value_l
-------------------------------------------------------------^[/bash]
By the way, I am using the following ifort version:
[bash]$ ifort -V
Intel Fortran Compiler XE for applications running on IA-32, Version 12.1.1.256 Build 20111011
Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY[/bash]
Any recommendation ?
oleglebedev
  CONTAINS
Best, Oleg.
FlyingHermes
It works just fine.
Thanks both of you.
