Bounds checking with GDB
gmadison
Here are my compiler flags
ifort -qopenmp
-g -m64 -fpp -O0 -debug all -check bounds -check uninit -traceback -g
While running this under gdb I see this error
forrtl: severe (408): fort: (2): Subscript #1 of the array NODES has value 10 which is greater than the upper bound..
I am seeing bounds errors listed, but I can't get GDB to break on the bounds error. Is there a symbol I can use to break on for a bounds error check? Or can a bounds error spit a backtrace out? so I can figure which line its coming from.
My guess is its coming from a statement like this (sorry for the formatting..)
queue(q_b1, i)%nodes(j)%count
Here is a BHNode
    type :: BHNode        |
       integer :: count        |
       integer,pointer,dimension(:) :: indices        |
       type(Vec3) :: min,max        |
       type(Vec3) :: pos,vel,acc        |
       type(BHNode),pointer :: parent        |
       type(BHNode),pointer,dimension(:) :: nodes        |
    end type BHNode        |
Where queue is defined
    type(BHNode),pointer,dimension(:,:) :: queue, temp_queue                                                        |
