29653 Discussions
Break command error message in intel debugger for linux
cassielinux
Hi
I am sorry if I post the question at the wrong place. Please let me know where is more appropriate for me to ask.
I am new to the idb/gdb debugger.I am trying to set a breakpoint in a fortran function called set_time_i which is in a file called time_manager.F90 by using idb. When I ran the executable file, I got error message such as
"Program received signal SIGFPE
TIME_MANAGER_MOD::set_time_i (set_time_i= (...), seconds=0, days=0, ticks=, err_msg=(...), .tmp.ERR_MSG.len_V$14b=0) at time_manager.F90:313"
So I tried to debug the error by setting breakpoint to the set_time_i.
However, idb keeps giving me error message and stops me from setting hte breakpoint. May I know if I did something wrong ? I tried all these commands:
1) (idb) break time_manager.F90:set_time_i
2) (idb) break time_manager:set_time_i
3) (idb) break set_time_i
4) (idb) break time_manager_:set_time_i_
The error message is
" break time_manager:set_time_i ^ Unable to parse input as legal command or Fortran expression."
None of above work. Did I miss something when I use it ? Thanks
TimP
This is the right place to ask.
I would suggest running nm on the .o file for the compilation of set_time_i to find the exact spelling of the break point name.
TimP
cassielinux
Thanks for replying.
So I typed shell> nm time_manager.o and it shows:
0000000000004d12 T time_manager_mod_mp_set_time_i_
Then, I typed shell> break time_manager_mod_mp_set_time_i_ and it worked ! What I do not understand is why the break point name is different from the function name ? Time_manager.F90 has been used as a module. Is this why that when the compiler generates the object files, it won't generate the object symbol as its function but a xxx_mod_mp_yyy name ? Does this only happen to Fortran ? I just do not understand where the part "..._mod_mp_" comes from.
Thank you very much,
Georg_Z_Intel
the "_mp_" infix is required by FORTRAN name mangling: module & function symbols are concatenated by inserting this separator in between.
IDB does this for you if you use the "." separator, e.g.:
(idb) break module.function
Hope that makes it easier for you.
Georg Zitzlsberger
