Break on data change
Nick2
In CVF there's a feature where code breaks execution whenever expression xyz changes value or becomes true. How do you do that in IVF 9.1?
Les_Neilson
Valued Contributor II
Right click on the break point and select Breakpoint Properties. Then click the Condition button on the dialog.
Les
Nick2
program FortranConsole1
implicit none
real a,b,c
c=0
a=0.23
b=0.45
c=a+b
(conditional breakpoint when c changes) print *, 'Hello World'
print *, c
end program FortranConsole1
Doesn't seem to work :-
Les_Neilson
Did youenter c in the edit box and tick the "has changed" radio button?
Les
Nick2
Yes.
