Browse for folder
algraham
I am new to IVF and I am attempting to display a BrowseForFolder dialog. I downloaded some code from the IVF forum (CmnDlgChooseFolder sample code posted by Paul-Curtis 02-24-2005) but I am having a couple of problems with it.
1. It calls CoTaskMemFree to free the memory allocated by the SHBrowseForFolder function. However CoTaskMemFree generates an unresolved exrernal error, even though I have the "use ole32" statement, in placeand I have added ole32.lib to the list of default libraries for the linker. I noticed that ole32.f90 does not include an interface for CoTaskMemFree, and so I have tried to create my own interface, but I can't get it right. Does anyone know how to use these functions correctly? Or is there another way to free the memory?
2. My BrowseForFolder dialog displays behind all other windows, instead of on top. Any idea why that would happen?
Help would begreatly appreciated - thanks very much.
Paul_Curtis
Valued Contributor I
Here is the missing Interface:
Code:
interface
  subroutine CoTaskMemFree (pvoid)
    !DEC$ IF DEFINED(_X86_)
    !DEC$ ATTRIBUTES STDCALL, ALIAS:'_CoTaskMemFree@4' :: CoTaskMemFree
    !DEC$ ELSE
    !DEC$ ATTRIBUTES STDCALL, ALIAS: 'CoTaskMemFree'   :: CoTaskMemFree
    !DEC$ ENDIF
    integer :: pvoid
  end subroutine CoTaskMemFree
end interface
Jugoslav_Dujic
Valued Contributor II
You probably gave it an invalid or NULL parent window handle.
XeffortLite sample contains module XFTFile which contains XBrowse wrapper routine for ShBrowseForFolder. It also allows you to specify the initial directory for the dialog (and I find the software which always lets you start browsing from "My Computer" very annoying).
Jugoslav
onkelhotte
New Contributor II
Code:
module BrowseFolder
	interface
		integer(4) function  SHBrowseForFolder (pBI)
			use mod_dialog
		!DEC$ ATTRIBUTES STDCALL, ALIAS:'_SHBrowseForFolderA@4' :: SHBrowseForFolder
		!DEC$ ELSE
		!DEC$ ATTRIBUTES STDCALL, ALIAS: 'SHBrowseForFolderA'   :: SHBrowseForFolder
		!DEC$ ENDIF
		!DEC$ ATTRIBUTES REFERENCE :: pBI
			TYPE(T_BROWSEINFO)	:: pBI
		end function SHBrowseForFolder
	end interface
	interface
		logical(4) function SHGetPathFromIDList (pidl, pszPath)
		!DEC$ ATTRIBUTES STDCALL, ALIAS:'_SHGetPathFromIDListA@8' :: SHGetPathFromIDList
		!DEC$ ELSE
		!DEC$ ATTRIBUTES STDCALL, ALIAS: 'SHGetPathFromIDListA'   :: SHGetPathFromIDList
		!DEC$ ENDIF
		!DEC$ ATTRIBUTES VALUE :: pidl
		!DEC$ ATTRIBUTES REFERENCE :: pszPath
			integer			:: pidl
			character*(*)	:: pszPath
		end function SHGetPathFromIDList
	end interface
end module
LOGICAL Function BrowseForFolder(dir)
use browsefolder
implicit none
TYPE T_BROWSEINFO
INTEGER hwndOwner
INTEGER pidlRoot
INTEGER pszDisplayName ! Return display name of item selected.
INTEGER lpszTitle ! text to go in the banner over the tree.
INTEGER ulFlags ! Flags that control the return stuff
INTEGER lpfn
INTEGER lParam ! extra info that's passed back in callbacks
INTEGER iImage ! output var: where to return the Image index.
END TYPE T_BROWSEINFO character*(*) dir integer lpIDList TYPE(T_BROWSEINFO) BI bi.hwndOwner = 0 bi.pidlRoot = NULL !Starts with Workspace bi.pszDisplayName = LOC(Dir) bi.lpszTitle = LOC("Please select directory:"C) bi.ulFlags = 1 !For selecting only directories and hard drives and not network enviroment and so on bi.lpfn = 0 bi.lParam = 0 bi.iImage = 0 lpIDList = SHBrowseForFolder(bi) IF (lpIDList.ne.0) THEN BrowseForFolder = SHGetPathFromIDList (lpIDList, dir) else BrowseForFolder = .false. END IF return end function
I use the following module for browsing folders.
Note that dir has a char(0) at the end of the string.
Markus
algraham
Thanks Paul-Curtis - the interface you provided works fine
algraham
Thanks Markus. I implemented this code and it works, but I get the same behaviour as before, i.e. that the Browse for Folder dialog is not visible.To seethec dialog I have to first minimize all windows, and then explicitly restore my application window. If I specify 0 in the bi.hwndOwner field the dialog opens in its own window. If I put the main window hwnd into this field, then the dialog displays as a child window of my main application window. However in both cases I have to first minimize all windows and then restore the application window in order to see it. Any ideas?
Thanks a lot
Lynn
algraham
Thanks Jugoslav. I downloaded the XFTLite sample and tried to use it. However, I seem to be missing some files that were not included in the download zip file: XFTApi, XFTCtrl, XFTTypes, and XFLOGM.
Is it possible to obtain these?
Also, with respect to my second problem, i.e. that the BrowseForFolder diolog does not display, pease see my reply to Markus.I think I am giving it a valid parent window handle (the hwnd of the main application window) but the dialog still does not display unless I fool around minimizing and restoring all other windows. If you have any further thoughts on this thatwould be great.
Lynn
Paul_Curtis
The browse dialog will appear on top of its parent window. The handle of this window is passed in the browseinfo structure:
bi%hwndOwner = hwndParent
Your sample code shows bi%hwndOwner = 0, which probably explains why your dialog always appears beneath all other windows.
Jugoslav_Dujic
Sorry, XFLOGM.f90 was indeed missing from the zip; I updated it now. (You don't need it for your project though -- only XFTFile and XFTStrings).
Either make sure that first !DEC$DEFINE XLITE line is uncommented, or specify XLITE in Project/Settings/Fortran/Preprocessor/Symbols. In this way, you "cut off" dependencies from other XFT* modules. (All library sources are in full Xeffort installation).
Jugoslav
algraham
I finally solved the problem in which my BrowseForFolder dialog was being displayed behind all other windows: I was responding to the WM_PAINT message in order to automatically display some graphical output, and this was interfering with all popup windows including message boxes. ObviouslyI was not doing it correctly. Anyway it all works now. Many thanks to all who replied to my questions and helped me along the way.
Lynn
alexeyam
Thanks. This is really very useful code. But I can not find module mod_dialog, that you use. What is in it? I use IVF 12. May be this module appears in other versions?
I wrote a module with this name and inserted a definition ofTYPE T_BROWSEINFO in it:
MODULEmod_dialog
USE ifwinty
TYPE T_BROWSEINFO
SEQUENCE
INTEGER(HANDLE) :: hwndOwner
INTEGER :: pidlRoot
INTEGER :: pszDisplayName
INTEGER :: lpszTitle
INTEGER :: ulFlags
INTEGER :: lpfn
INTEGER(fLPARAM) :: lParam
INTEGER :: iImage
END MODULEmod_dialog
Without this module compler reported about undefined structureT_BROWSEINFO.
Now after compiling with your code it says:
error #6633: The type of the actual argument differs from the type of the dummy argument. [BI]
May be something else wrong?
anthonyrichards
New Contributor III
Did you also find the following list of useful flags for browsing?
integer, parameter :: BIF_DONTGOBELOWDOMAIN =Z'0002' ! For starting the Find Computer
integer, parameter :: BIF_STATUSTEXT =Z'0004' ! Top of the dialog has 2 lines of text for BROWSEINFO.lpszTitle and one line if
! this flag is set. Passing the message BFFM_SETSTATUSTEXTA to the hwnd can set the
! rest of the text. This is not used with BIF_USENEWUI and BROWSEINFO.lpszTitle gets
! all three lines of text.
integer, parameter :: BIF_RETURNFSANCESTORS =Z'0008'
integer, parameter :: BIF_EDITBOX =Z'0010' ! Add an editbox to the dialog
integer, parameter :: BIF_VALIDATE =Z'0020' ! insist on valid result (or CANCEL)
integer, parameter :: BIF_NEWDIALOGSTYLE =Z'0040' ! Use the new dialog layout with the ability to resize
! Caller needs to call OleInitialize() before using this API
integer, parameter :: BIF_USENEWUI = IOR(BIF_NEWDIALOGSTYLE , BIF_EDITBOX)
integer, parameter :: BIF_BROWSEINCLUDEURLS =Z'0080' ! Allow URLs to be displayed or entered. (Requires BIF_USENEWUI)
integer, parameter :: BIF_UAHINT =Z'0100' ! Add a UA hint to the dialog, in place of the edit box. May not be combined with BIF_EDITBOX
integer, parameter :: BIF_NONEWFOLDERBUTTON =Z'0200' ! Do not add the "New Folder" button to the dialog. Only applicable with BIF_NEWDIALOGSTYLE.
integer, parameter :: BIF_NOTRANSLATETARGETS=Z'0400' ! don't traverse target as shortcut
integer, parameter :: BIF_BROWSEFORCOMPUTER =Z'1000' ! Browsing for Computers.
integer, parameter :: BIF_BROWSEFORPRINTER =Z'2000' ! Browsing for Printers
integer, parameter :: BIF_BROWSEINCLUDEFILES=Z'4000' ! Browsing for Everything
integer, parameter :: BIF_SHAREABLE =Z'8000' ! sharable resources displayed (remote shares, requires BIF_USENEWUI)
integer, parameter :: BFFM_INITIALIZED = 1
alexeyam
I am not experienced programmist, I am scientist. I have found on another forum one more example of using function "Browse for folder", but it required more unknown modules as well. But after two days of dancing withtambourine around computer I made a compilation of these examples and made some modifications. Now It works as I wish, but with one issue, that is important. I could not control setting of the initial folder. Here is code I wrote. I tried to set as initial folder C:\Program Files, but it did not work. Debugger shows, that when I try to get PIDL of the initial forder, functionSHSimpleIDListFromPath always returns 0.
Here is code; may be somebody will find in it some stupid errors.
LOGICAL Function BROWSEFORFOLDER(dir)
use browsefolder
USE ifwinty
use ExtraWinTy
USE user32
implicit none
character*(*) dir
integer lpIDList, iret
INTEGER(4) itemidlistptr, initdirptr
CHARACTER(511) initdir
initdirptr = LOC('C:\\Program Files'C) !Trying to set initial folder 'C:\Program Files'
itemidlistptr = SHSimpleIDListFromPath (initdirptr)
bi.hwndOwner = GetForegroundWindow()
bi.pidlRoot = itemidlistptr !NULL !Starts with Workspace
bi.ulFlags = BIF_RETURNONLYFSDIRS .XOR. BIF_NEWDIALOGSTYLE
bi.lpfn = 0
bi.lParam = 0
bi.iImage = 0
iret = CoInitializeEx (NULL, COINIT_APARTMENTTHREADED ) ! Needed for BIF_NEWDIALOGSTYLE flag
else
END IF
CALL CoUninitialize () ! Needed for CoInitializeEx
return
end function
MODULE ExtraWinTy
USE ifwinty
integer, parameter :: BIF_RETURNONLYFSDIRS = #00000001 ! For finding a folder to start document searching
integer, parameter :: BIF_DONTGOBELOWDOMAIN = #00000002 ! For starting the Find Computer
integer, parameter :: BIF_STATUSTEXT = #00000004
integer, parameter :: BIF_RETURNFSANCESTORS = #00000008
integer, parameter :: BIF_EDITBOX = #00000010
integer, parameter :: BIF_BROWSEFORCOMPUTER = #00001000 ! Browsing for Computers.
integer, parameter :: BIF_BROWSEFORPRINTER = #00002000 ! Browsing for Printers
integer, parameter :: BIF_BROWSEINCLUDEFILES = #00004000 ! Browsing for Everything
integer, parameter :: BIF_NONEWFOLDERBUTTON = #00000200
integer, parameter :: BIF_NEWDIALOGSTYLE = #00000040
TYPE T_BROWSEINFO
SEQUENCE
INTEGER :: pidlRoot
INTEGER :: ulFlags
INTEGER :: lpfn
INTEGER :: iImage
TYPE ****EMID
SEQUENCE
INTEGER(2) :: cb
INTEGER(1) :: abID
END TYPE ****EMID
TYPE ITEMIDLIST
SEQUENCE
TYPE(****EMID) :: mkid
END TYPE ITEMIDLIST
END MODULE ExtraWinTy
MODULE BrowseFolder
interface
use ExtraWinTy
!DEC$ ELSE
!DEC$ ENDIF
end interface
interface
!DEC$ ELSE
!DEC$ ENDIF
integer :: pidl
end interface
INTERFACE
INTEGER(4) FUNCTION CoInitializeEx (pvReserved, dwCoInit)
!DEC$ ATTRIBUTES STDCALL, ALIAS:'_CoInitializeEx@8' :: CoInitializeEx
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS: 'CoInitializeEx' :: CoInitializeEx
!DEC$ ENDIF
!DEC$ ATTRIBUTES VALUE :: pvReserved
!DEC$ ATTRIBUTES REFERENCE :: dwCoInit
INTEGER(4) :: pvReserved
INTEGER(4) :: dwCoInit
END FUNCTION
END INTERFACE
INTERFACE
SUBROUTINE CoUninitialize ()
!DEC$ ATTRIBUTES STDCALL, ALIAS:'_CoUninitialize@0' :: CoUninitialize
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS: 'CoUninitialize' :: CoUninitialize
!DEC$ ENDIF
END SUBROUTINE
END INTERFACE
INTERFACE
INTEGER(4) FUNCTION SHSimpleIDListFromPath (pszPath)
!DEC$ ATTRIBUTES STDCALL, ALIAS:'_SHSimpleIDListFromPath@4' :: SHSimpleIDListFromPath
!DEC$ ELSE
!DEC$ ATTRIBUTES STDCALL, ALIAS: 'SHSimpleIDListFromPath' :: SHSimpleIDListFromPath
!DEC$ ENDIF
INTEGER(4) :: pszPath
END FUNCTION
END INTERFACE
END MODULE
Paul_Curtis
This works for me, and starts out in the supplied path:
[bash]! Shows a folder chooser shell window. The path to the chosen
! folder is placed in folderPath, which is a character array of
! the specified length. Returns true if the user chose a folder,
! or false if the operation was cancelled. The title caption
! is specified as a string table resource ID in the optional
! argument title.
LOGICAL FUNCTION CmnDlgChooseFolder (hwndParent, folderPath, title)
	USE ExtraWinTy
	USE ifcom, only: COMInitialize, COMUnInitialize
    IMPLICIT NONE
    INTEGER(HANDLE), INTENT(IN)          :: hwndParent
    CHARACTER(LEN=*), INTENT(INOUT)      :: folderPath
    INTEGER, INTENT(IN), OPTIONAL		 :: title       ! stringtable id value
    TYPE(T_BROWSEINFO)				  	 :: bi
    CHARACTER(LEN=MAX_PATH)				 :: buffer
    INTEGER								 :: pidl		! pointer to id list
    INTEGER								 :: status, rval2
    CHARACTER(LEN=200)					 :: titleBuffer
    INTEGER								 :: titleId
    TYPE(T_STRRET)					     :: rstring
    INTEGER								 :: IShellFolder_desktop
	CmnDlgChooseFolder = .FALSE.
	IF (PRESENT(title)) THEN
        titleId = title
    ELSE
        titleId = IDS_DEFAULT_CHOOSEFOLDER_TITLE
    END IF
    titleBuffer = STGet(titleId, 200)
	CALL COMInitialize (status)
    buffer = folderPath
    !    TYPE T_BROWSEINFO
    !        SEQUENCE
    !        INTEGER                        :: hwndOwner
    !        INTEGER                        :: pidlRoot
    !        INTEGER                        :: pszDisplayName
    !        INTEGER                        :: lpszTitle
    !        INTEGER                        :: ulFlags
    !        INTEGER                        :: lpfn
    !        INTEGER                        :: lParam
    !        INTEGER                        :: iImage
    !    END TYPE T_BROWSEINFO
    bi%pidlRoot       = NULL
    bi%pszDisplayName = LOC(buffer)
    bi%lpszTitle      = LOC(titleBuffer)
    bi%ulFlags        = BIF_RETURNONLYFSDIRS
    bi%lpfn           = NULL
    bi%lParam         = 0
    bi%iImage         = 0
    !	SHBrowseForFolder returns an item identifier list.
    pidl = SHBrowseForFolder (bi)
    IF (pidl /= 0) THEN
		SELECT CASE (windows_version)
		!	Win95 and Win98
		CASE (VER_PLATFORM_WIN32_WINDOWS)
			! We need to ask the shell to decode the item identifier
			! list into a parseable name. First, retrieve an IShellFolder
			! COM interface handle to the desktop folder.
			rval2 = SHGetDesktopFolder(LOC(IShellFolder_desktop))
			IF (rval2 == NOERROR) THEN
				! Use the GetDisplayNameOf method to convert the item
				! identifier list into a string. The SHGDN_FORPARSING flag
				! indicates we want the parseable path, not the general-
				! purpose display label.
				rstring%uType = STRRET_CSTR
				rval2 = IShellFolder_GetDisplayNameOf (IShellFolder_desktop,&
													   pidl,				&
													   SHGDN_FORPARSING,	&
													   LOC(rstring)			)
					folderPath = rstring%cStr
					CmnDlgChooseFolder = .TRUE.
				END IF
			END IF
		!	WinNT, Win2K, WinXP
		CASE (VER_PLATFORM_WIN32_NT)
			CmnDlgChooseFolder = SHGetPathFromIDList (pidl, folderPath)
		END SELECT
        CALL CoTaskMemFree (pidl)
    END IF
	CALL COMUnInitialize ()
END FUNCTION CmnDlgChooseFolder
[/bash]
anthonyrichards
New Contributor III
your call to
fails because initdirptr must point to a WIDE character string, that is a string consisting of 2 bytes-per-character.
try this:
CHARACTER(256) STARTPATH1
INTEGER(2) UCPATH1(256)
INTEGER IACP, IBYTESNEED, IBYTESWRITTEN,IWIDE
INTEGER ITEMIDLISTPTR
STARTPATH1="C:\PROGRAM FILES"//CHAR(0) ! Must be a null-terminated string
UCPATH1=0
IACP=GetACP() ! get the code page in use
IWIDE=0
! find out how many bytes are needed...
IBYTESNEED=MultiByteToWideChar(IACP, 0, STARTPATH1,-1,UCPATH1, IWIDE)
!..then write them to UCPATH1..
IBYTESWRITTEN=MultiByteToWideChar(IACP, 0, STARTPATH1,-1,UCPATH1, IBYTESNEED)
UCPATH1(IBYTESWRITTEN+1)=0 ! terminate with an added zero
ITEMIDLISTPTR=SHSimpleIDListFromPath (LOC(UCPATH1))
and you should get a meaningful pointer value for ITEMIDLISTPTR
By the way, "C:\program files" has its own PIDL value = CSIDL_PROGRAM_FILES
alexeyam
Thanks, Paul.
I tried to compile it, but failed. Compiler output (some errors concernet to indefined names):
error #6404: This name does not have a type, and must have an explicit type.   [STGET]
error #6404: This name does not have a type, and must have an explicit type.   [SHBROWSEFORFOLDER]
error #6404: This name does not have a type, and must have an explicit type.   [WINDOWS_VERSION]
error #6404: This name does not have a type, and must have an explicit type.   [SHGETDESKTOPFOLDER]
error #6404: This name does not have a type, and must have an explicit type.   [STRRET_CSTR]
error #6404: This name does not have a type, and must have an explicit type.   [SHGDN_FORPARSING]
error #6404: This name does not have a type, and must have an explicit type.   [ISHELLFOLDER_GETDISPLAYNAMEOF]
error #6404: This name does not have a type, and must have an explicit type.   [SHGETPATHFROMIDLIST]
I could not find definitions for these names in the IVF include files. May be they are somewhere else?
String 52:
bi%pidlRoot=NULL
It looks like it starts from the Decktop, not from the supplied path.
alexeyam
Thanks, anthonyrichards.
After I added your code to my and added 'USE kernel32' stringcompiler built application without error reports. But when I run my program and called this function it showed wrong behavior. I tried to use as a starting folder E:\Data. First, a mesage appeared:
The folder E:\Data cannot be used. Please choose another folder.
After I pressed OK, browse for folder dialog appeared, but in wrong kind. It did not contain any folders except E:\Data, but it had improper view and had no subfolders. Screenshots attached. After I pressed Cancel and closed my application it crashed: An unhandled win32 exception occurred in Myprogram.exe [4576].
anthonyrichards
New Contributor III
can you post the contents of your T_BROWSINFO structure?
And a screen shot of Windows explorer opened at E:\data?
alexeyam
anthonyrichards, thanks.
Here is the contents ofT_BROWSINFO:
bi.pidlRoot = ITEMIDLISTPTR
bi.lpfn = 0
bi.lParam = 0
bi.iImage = 0
Here is the screenshot:
anthonyrichards
New Contributor III
try using different folders, say on the C: disk. Clearly the problem you found is not with creating the wide-character string it would appear, but some other combination of other events.
Try setting the flags to zero so the defaults are used.
I have tried your code on an XP Pro system and it works fine, except I do not have an e:\data disk so have to use different folder name.
Is there anything special about your E:\data disk?
anthonyrichards
New Contributor III
Please also note (from http://msdn.microsoft.com/en-us/library/windows/desktop/bb762115%28v=vs.85%29.aspx):
NoteIf COM is initialized using CoInitializeEx with the COINIT_MULTITHREADED flag, SHBrowseForFolder fails if the calling application uses the BIF_USENEWUI or BIF_NEWDIALOGSTYLE flag in the BROWSEINFO structure.
It is the responsibility of the calling application to call CoTaskMemFree to free the IDList returned by SHBrowseForFolder when it is no longer needed.
Perhaps remove the BIF_NEWDIALOGSTYLE flag?...
