Bug in Fortran Visual Compiler
h_amini
Hi there
I think I found a bug in Visual Fortran Compiler 10.1.025. It is about a subroutine used to solve nonlinear equations with MFP approach (see below). The brief code is to apply equation Y = X^2 - 25 just for checking purpose.
The problem is that when I add two printing commands on lines 10 and 20, the code works perfectly, but when I omit them it does not! In fact, it can be checked by inputting 0.001, 100, 1 and 10 respectively to get X= 5.
Could someone let me know if it is a bug or I made a mistake? I compiled the subroutine with another compiler and it worked even after omitting the two printing commands.
Many thanks
Hamid
1 READ*, ERS, IMAX, EPSDPER, EPSDMAX
EPSL = EPSDPER; EPSU = EPSDMAX
CALL MFP(EPSL, EPSU, EPSD, ERS, ERA, ITER, IMAX)
GO TO 1
END
FUNCTION F(X)
F = X**2-25
RETURN
END
SUBROUTINE MFP(EPSL, EPSU, EPSD, ERS, ERA, ITER, IMAX)
ITER = 0
FL = F(EPSL)
FU = F(EPSU)
10 PRINT*, 'FL=', FL, 'FU=', FU
DO
EPSDOLD = EPSD
EPSD = EPSU - FU * (EPSL - EPSU) / (FL - FU)
20 PRINT*, 'EPSL=', EPSL, 'EPSU=', EPSU
FR = F(EPSD)
ITER = ITER + 1
C print*, 'iter=', iter
C100 PRINT*, 'EPSD=', EPSD
IF (EPSD.NE.0) ERA = ABS((EPSD - EPSDOLD) / EPSD) * 100
PRINT*, 'ERA=', ERA
TEST = FL * FR
IF (TEST.LT.0) THEN
EPSU = EPSD
FU = F(EPSU)
IU = 0
IL = IL + 1
IF (IL.GE.2) FL = FL / 2
ELSE IF (TEST.GT.0) THEN
EPSL = EPSD
FL = F(EPSL)
IL = 0
IU = IU + 1
IF (IU.GE.2) FU = FU / 2
ELSE
ERA = 0
END IF
print*, 'ERA=', ERA
IF (ERA.LT.ERS .OR. ITER.GT.IMAX) EXIT
END DO
AMFP1 = EPSD
PRINT*, 'X=', AMFP1
RETURN
END
ender01
Quoting - h.amini
Hi Rich
Appreciated very much for your kind consideration of the problem.
The posted program gives the same wrong answer (X= 3.181818) after commenting the printing statements. However, as you annotated EPSDOLD is not initialized (Jim also mentioned the same about EPSD - thank you Jim). So, when I initialize EPSD or EPSDOLD to zero, the program works perfectly even if the floating point numbers are not double precision.
Interestingly, when I do not initialize them to zero and print them, they are zero! But sometimes the program does not work correctly depending on the printing statements. For example, in the following code, when lines 31, 32 and 33 are stated, the result is right:
.001
100
1
10
epsd 0.0000000E+00
epsd 0.0000000E+00
epsd 0.0000000E+00
epsd 3.181818
epsd 4.310345
epsd 5.142132
epsd 4.989630
epsd 4.999855
epsd 5.000141
X= 5.000000
but, when just one of the printing lines is commented, the result is wrong:
.001
100
1
10
epsd 0.0000000E+00
epsd 0.0000000E+00
X= 3.181818
If you could forward it to the developers, it may be interesting for them. The compiler I am using is: Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.0 Build 20080930 Package ID: w_cprof_p_11.0.061.
FUNCTION F(X)
F = X**2-25
RETURN
END
ITER = 0; IL = 0; IU = 0; !EPSD = 0
31 print*, 'epsd',epsd
FL = F(EPSL)
FU = F(EPSU)
32 print*, 'epsd',epsd
DO
33 print*, 'epsd',epsd
EPSDOLD = EPSD
FR = F(EPSD)
ITER = ITER + 1
TEST = FL * FR
IF (TEST.LT.0) THEN
EPSU = EPSD
FU = F(EPSU)
IU = 0
IL = IL + 1
EPSL = EPSD
FL = F(EPSL)
IL = 0
IU = IU + 1
ELSE
ERA = 0
END IF
END DO
AMFP1 = EPSD
PRINT*, 'X=', AMFP1
RETURN
END
GO TO 1
END
Many thanks
Hamid
Hi Hamid,
It looks like EPSD is not being updated as it's supposed to be (2 lines after the line numbered 33). If it's staying at zero (the default value) this means that your convergence condition is not going to be properly evaluated:
[cpp]IF(EPSD.NE.0) THEN
END IF
[/cpp]
ERA is not evaluated and so stays at its default (uninitialized value) of 0 (which is less than ERS). Which would kick you out after the first pass with the current value of EPSD. But we know that the first evaluation is 3.18181...
It looks like a compiler bug. Can you run the debugger and track EPSD? Does this happen when you run the debugger (different compiler options - less optimization)?
Rich
h_amini
Quoting - ender01
Hi Hamid,
IF(EPSD.NE.0) THEN ERA = ABS((EPSD - EPSDOLD) / EPSD) * 100 END IF
Rich
Many thanks Rich
You are right. It seems there is a bug in the compiling optimization. In fact, when I disable optimizations with /debug:full the problem is solved. Also, when optimization level o1 is applied the program works perfectly. However, applying optimization level o2 or o3 causes the problem.
Hamid
Jugoslav_Dujic
Valued Contributor II
NO! NO! THOUSAND TIMES NO!
Please, get rid of the misconception that the "default, uninitialized value" is zero. It started this whole long thread and misunderstanding. It is NOT zero. It is a (semi-)RANDOM value. When it happens to be zero (or small enough), you get the "right" results, and otherwise you get the "wrong" results. But it's NOT, again, compiler's duty to make sure it is initialized to zero, unless you explicitly say so.
Sorry for yelling, but this is a very important concept to grasp, and you'll encounter many problems if you fail to adopt it.
ender01
Quoting - Jugoslav Dujic
While there is no Fortran standard for this, most compilers do handle this with a default (most even document it). Yell all you want, but what's important to realize is not that there is not a "default, uninitialized zero" but that compilers handle the condition differently and if you want any portability, you'd best not ignore it. If you'll read the posts above, you'll find that Hamid noted that his compiler was initializing the variable to zero. I can assure you that that was not an accident but was the result of an optimizing compiler setting a default value to an uninitialized variable.
jugoslavdujic2
Quoting - ender01
No. "Optimizing compiler" does not apply any defaults to uninitialized variables -- it is an accident. In my experience, the values are often reproducible (i.e. not entirely random -- that's why I referred to it as "semi-random" above), but generally different depending on optimization level and, worse still, depend whether it is run under debugger or not. You cannot -- and shouldn't -- make any assumption about those values.
The worst kind of bugs ("heisenbugs") appear only when run outside the debugger, or even only on customer's computer, and are commonly assigned to uninitialized variables.
ender01
Quoting - jugoslavdujic2
Again, different compilers do different things. Pounding your fist on the table saying it ain't so won't change that. I've worked with a lot of different Fortran compilers (of widely differing quality) on a lot of different systems (of widely differing quaiity) and I have seen compiler switch options that enable and disable the option to control a default assignment to an unitialized variable. It was even occasionally made explicit in the documentation that this was a non-standard Fortran setting. That being said, yes, some compilers don't provide any such reproducible default.
In any case, default or not, I would never suggest that it's acceptable practice to rely upon a default nor did I in any of my posts. In fact my advice was quite the opposite, start looking at the variables and how they're defined. I think that we're in violent agreement on that point. The fact that Hamid explicitly commented on the "repeatable" initialization of the variable to zero was the basis of my comment (and I'll bet it was right too).
In closing, don't come "yelling" like this about anything. Frankly, not knowing anything about you, I don't particularly have any reason to trust your "experience" and you sure haven't given me any.
Jugoslav_Dujic
Quoting - ender01
Well, we probably are in "violent agreement" as you said; let's bury the hachets.
I am aware I was harsh in my first post, but it was my knee-jerk reaction to sentence which read, quote again, "ERA is not evaluated and so stays at its default (uninitialized value) of 0". Maybe I'm guilty of jumping to conclusion of what you actually meant, but my reading was (and I think that you can see how it can easily be misread) that this means that ERA is automagically initialized to 0.
Yes, many compilers through the history did initialize to zero, and most still have an option to do so (/Qsave /Qzero for ifort). Many (l)users even relied on it. But it has never been part of the Standard, and there are certainly many bugs lurking around waiting to rear its ugly head in many "trusted" codes.
ender01
Great, thank you. No harm, no foul. I can see your point, but I think the context here is important. I was trying to be more pendagogical and lead Hamid to paying more attention to how variable are defined and used, and, ultimately to understanding what the ramifications are. It is a lot less important to know what value was assigned than to understand what can happen if you don't define variables properly. The specific mechanism through which a value is assigned is beside the point. Perhaps I should have been more precise but I felt it would be more productive to illustrate the the fact that you can't rely on a consistent automatic assignment (you'll note that I pointed out that my program did not initialize thet variable to zero) than to discuss the details of compiler design. I'll also note that I know of no commercial Fortran compiler (I'm not claiming an exhaustive study here) that does not specifically address undefined variables as part of its design. Though it may not be discussed in the documentation provided (and may explicitly warn against using an uninitialized variable in a computatoin), I've never seen an uninitialized variable merely given the contents of the address referenced by the variable (and if you've ever had an array subscript go out of bounds, you know what those numbers can look like). And you're absolutely right about the "trusted code" though I'd add that that set of code includes operating systems, IDEs, and even compilers.
ender01
anthonyrichards
New Contributor III
Quoting - ender01
