29386 Discussions
Bug in interface generation: upper bounds are dropped
Cross__Mat
I'm using
> ifort --version
ifort (IFORT) 12.1.0 20111011
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
on
> uname -a
Linux stonehenge 3.1.1-2.fc16.x86_64 #1 SMP Mon Nov 14 15:46:10 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
With input source
> cat ub.f90
subroutine sub(x,n)
integer :: n, x(n,1:2)
end
I see the final upper bound 2 is dropped
> ifort -c -gen-interfaces ub.f90 ; ifort -c sub__genmod.f90
sub__genmod.f90(6): error #6644: The dimension specifications are incompatible.
INTEGER(KIND=4) :: X(N,1:)
compilation aborted for sub__genmod.f90 (code 1)
How amusing - thanks. I have escalated this as issue DPD200176329. The generated .mod appears to work correctly, so this is just a "cosmetic" issue in the .f90, which is not used by the compiler. Still, we recognize that some people do use this generated source so we should fix the bug.
This has been fixed for a release later this year.
