I got the following message running [plain]ifort (IFORT) 13.1.0 20130121[/plain] in RHEL 5 x86_64:
[plain]
single_point_streaming_stats.F90: catastrophic error: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
[/plain]
The compiler was invoked as:
[bash]
$ ifort -warn -stand f08 -syntax-only single_point_streaming_stats.F90
[/bash]
This brings me to my second (related) bug report/feature request: Would it be possible to have ifort perform the appropriate pre-processing when the -syntax-only flag is used? Or at least add a flag to enable pre-processing before feeding the code to the syntax checker? (note the .F90 extension) Note that fpp does not complain about any errors in pre-processor directives, and that if I replace the -syntax-only flag with -c it compiles without errors.
Below is a listing of all the errors and warnings created along with the catastrophic error:
[plain]
single_point_streaming_stats.F90(2): warning #5117: Bad # preprocessor line
#ifdef DEBUGGING
single_point_streaming_stats.F90(3): warning #5117: Bad # preprocessor line
#define IS_ELEMENTAL
single_point_streaming_stats.F90(4): warning #5117: Bad # preprocessor line
#define IS_PURE
single_point_streaming_stats.F90(5): warning #5117: Bad # preprocessor line
#else
single_point_streaming_stats.F90(6): warning #5117: Bad # preprocessor line
#define IS_ELEMENTAL elemental
single_point_streaming_stats.F90(7): warning #5117: Bad # preprocessor line
#define IS_PURE pure
single_point_streaming_stats.F90(8): warning #5117: Bad # preprocessor line
#endif
single_point_streaming_stats.F90(25): error #5082: Syntax error, found IDENTIFIER 'FUNCTION' when expecting one of: ( % [ : . = =>
IS_ELEMENTAL function spss_op_spss(lhs,rhs) result(res)
single_point_streaming_stats.F90(25): error #5082: Syntax error, found IDENTIFIER 'RESULT' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ' ** / ...
single_point_streaming_stats.F90(25): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: :
single_point_streaming_stats.F90(30): error #5082: Syntax error, found IDENTIFIER 'FUNCTION' when expecting one of: ( % [ : . = =>
IS_PURE function spss_op_real(lhs,rhs) result(res)
single_point_streaming_stats.F90(30): error #5082: Syntax error, found IDENTIFIER 'RESULT' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ' ** / ...
single_point_streaming_stats.F90(30): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: :
single_point_streaming_stats.F90(36): error #5082: Syntax error, found IDENTIFIER 'FUNCTION' when expecting one of: ( % [ : . = =>
IS_PURE function spss_op_realvec(lhs,rhs) result(res)
single_point_streaming_stats.F90(36): error #5082: Syntax error, found IDENTIFIER 'RESULT' when expecting one of: ( * ) :: , <END-OF-STATEMENT> ; . % (/ + - [ : ] /) . ' ** / ...
single_point_streaming_stats.F90(36): error #5082: Syntax error, found END-OF-STATEMENT when expecting one of: :
single_point_streaming_stats.F90(42): error #5082: Syntax error, found IDENTIFIER 'SUBROUTINE' when expecting one of: ( % [ : . = =>
IS_ELEMENTAL subroutine spss_eq_spss(lhs,rhs)
single_point_streaming_stats.F90(47): error #5082: Syntax error, found IDENTIFIER 'SUBROUTINE' when expecting one of: ( % [ : . = =>
IS_PURE subroutine spss_eq_real(lhs,mean) ! constructor of sorts
single_point_streaming_stats.F90(42): error #6622: This statement is invalid in an INTERFACE block.
single_point_streaming_stats.F90(47): error #6622: This statement is invalid in an INTERFACE block.
single_point_streaming_stats.F90(26): error #8041: The IMPORT statement is not positioned correctly within the scoping unit.
import :: spss_t
single_point_streaming_stats.F90(27): error #6643: This statement is incorrectly positioned.
class(spss_t) ,intent(in) :: lhs, rhs
single_point_streaming_stats.F90(28): error #6643: This statement is incorrectly positioned.
class(spss_t), allocatable :: res
[/plain]
Also, note that the pre-processor directives are valid as far as I can tell, and produce no complaints when fpp is run first.
Thanks, -Z
You need to supply the -fpp option for ifort to invoke the preprocessor. (it is not on by default as with C/CPP)
Jim Dempsey
On Linux/OS X, the use of the .F90 file type (as opposed to .f90) automatically runs fpp.
Z, thanks, we'll take a look.
I reproduced and escalated both problems. The ICE is issue DPD200243576, the failure to run fpp when -syntax-only is specified is DPD200243577.
Thanks Steve.
Jim, the Composer XE 2013 2.146 man pages make no reference to an -fpp option. The -E flag will just run the preprocessor and output the results of preprocessing to stdout, but then -warn and -syntax-only are not run AFAICT.
The man pages don't list all options. If you add -fpp, it works. You shouldn't have to do that, though, which is a bug.
A fix has been found for both DPD200243576 and DPD200243577. We are planning to include these fixes in the next major release which is currently scheduled for later this year.
Thanks for the hard work and first class support.
Dear All,
I am new in linux and ifort and I have exactly the same problem that when I want to compile the code I receive the error:
OCNGISSVM.f(4): warning #5117: Bad # preprocessor line #include "rundeck_opts.h"
As I am new I don't know how to supply the -fpp option for ifort to invoke the preprocessor. Please can you help me where to change it,
as anybody cannot help me, thanks
Anna,
You have two choices. One is to find the place in your makefile or other build script where ifort is invoked and add -fpp to the list of compiler options. The other is to rename the source file to have a file type of .F90 (or .F if fixed-form source) with a capital letter F.
Anna,
It would be useful to know more about your build system, but I'll try to answer based on what you've included here.
When you compile OCNGISSVM.f you should add the -fpp option to ifort:
[bash] ifort -fpp <other compile and/or linker options> OCNGISSVM.f [/bash]
How is the program built? Are you calling ifort directly or typing `make <exe/target name>`? Is OCNGISSVM.f just one of many source files needed to build your program or do you compile and link it in one step since it is the only source file, other than the #includes? Another alternative would be to stop relying on preprocessor includes and use the native Fortran include statement, however this is deprecated since at least F2008:
[fortran]C ! original
#include rundeck_opts.h
C ! change to:
INCLUDE "rundeck_opts.h"
[/fortran]
If you keep the original #include preprocessor directive (the best option IMO) you may consider changing the extension on the file name from OCNGISSVM.f to OCNGISSVM.F, since it is a common convention that Fortran source files that require pre-processing use a capital "F" instead of lowercase in the file name extension. (e.g. .F instead of .f or .F90 instead of .f90) You can do this with the `mv` command: [bash] mv OCNGISSVM.f OCNGISSVM.F[/bash]
