29636 Discussions
Bug(?) with elemental function and allocatable actual argument
Wolf_W_
Hello!
I am getting some odd results, when i try to use the allocatable return value of a function directly as an argument of another function. Is this behavior intendet, or is this usage of the elemental-keyword false? I use the 15.0.2 compiler.
program main
  implicit none
  character(4)              :: test_char = "Test"
  character(:), allocatable :: temp_alloc
  character(10)             :: temp_fixed
  ! This should be the result
  ! 'Test\foo'
  write(*,*) test_char // "\" // foo()
  ! This is the result
  ! 'foo f .'
  write(*,*) concat(test_char, foo())
  ! It works as intendet, when the result of 'foo' is stored in a variable
  temp_alloc = foo()
  write(*,*) concat(test_char, temp_alloc)
  temp_fixed = foo()
  write(*,*) concat(test_char, temp_fixed)
contains
  function foo()
    character(:), allocatable :: foo
    foo = "foo"
  end function foo
! There are no problems without the 'elemental'-keyword
  elemental function concat(var1,var2) result(var_result)
    character(*), intent(in) :: var1, var2
    character(len=max(len(var1),1)+len(var2)+1) :: var_result
!    character(8) :: var_result ! This does not work, too.
    var_result = var1 // "\" // var2
  end function concat
end program
FortranFan
To me, this appears to be a bug in Intel Fortran.  I too fail to find anything in the Fortran standard that would preclude the use of elemental functions in such a context.  But you may want to consider posting this on comp,lang.fortran to see what a broad spectrum of folks (some with detailed knowledge of the standard) think of this.
I think this is a known bug, but I will check when I get back to the office Thursday.
