29386 Discussions
Bugs or unnecessary restrictions with ALLOCATE?
OP1
New Contributor III
The following program triggers a compilation error with the latest OneAPI ifort compiler (2021.5.0).
PROGRAM P
IMPLICIT NONE
INTEGER, ALLOCATABLE :: X(:)
REAL, ALLOCATABLE :: Y(:)
ALLOCATE(X, MOLD = Y)
END PROGRAM P
The compiler error is:
error #8155: In an ALLOCATE statement the source expression in SOURCE= or MOLD= specifiers must be of the same type and kind type parameters as the object being allocated. [Y]
I understand the restriction when SOURCE= is used, but I am not sure this restriction is necessary for MOLD=. What am I missing here?
There is a somewhat similar issue with this other example:
PROGRAM P
IMPLICIT NONE
TYPE :: T
END TYPE T
CLASS(T), ALLOCATABLE :: X(:)
ALLOCATE(T :: X, MOLD = Y)
END PROGRAM P
error #8157: If source expression in SOURCE= or MOLD= specifiers in an ALLOCATE statement, a TYPE specification must not appear for the object being allocated.
Again, this restriction sounds superfluous.
In both examples the type of X is known in advance. In order to allocate X the only knowledge required is the shape of the MOLD argument Y.
Steve_Lionel
I did some more careful reading of the 202X draft. In 202X you will be able to do this:
PROGRAM P
IMPLICIT NONE
ALLOCATE(X(lbound(y):ubound(y)))
END PROGRAM P
Steve_Lionel
The standard sez:
R927 allocate-stmt is ALLOCATE ( [ type-spec :: ] allocation-list [ , alloc-opt-list ] )
R928 alloc-opt is ERRMSG = errmsg-variable
 or MOLD = source-expr
 or SOURCE = source-expr
 or STAT = stat-variable
C945 (R927) Each allocate-object shall be type compatible (7.3.2.3) with source-expr.
The MOLD source-expr must be type-compatible with the allocate-object. INTEGER is not type-compatible with REAL.
OP1
New Contributor III
Thanks Steve. I wish the ALLOCATE intrinsic were capable to handle those two cases:
1. If the allocate-object and MOLD source-expr are type compatible, then the allocate-object is allocated to the type and bounds (if it is an array) of source-expr (the current behavior).
2. If the allocate-object has a type known at compile time; or if it has a dynamic type and type-spec:: is present, then the allocate-object is allocated to the bounds of source expr.
Case 2. would help 'apply'  the bounds of an allocatable array to another, no matter what the type-compatibility between the two is.
jimdempseyatthecove
PROGRAM P
IMPLICIT NONE
ALLOCATE(Y(-12:34))
ALLOCATE(X(LBOUND(Y):UBOUND(Y)) ! requires Y be allocated
END PROGRAM P
In place of MOULD use bounds.
Jim Dempsey
OP1
New Contributor III
Thanks Jim - yes, that is a solution obviously (with one small correction: you need the DIM argument in LBOUND and UBOUND). For arrays of rank greater than 1 this would look like:
ALLOCATE(X(LBOUND(Y, DIM=1):UBOUND(Y, DIM=1), LBOUND(Y, DIM=2):UBOUND(Y, DIM=2), etc.))
But this is not as clean as something that would look like this:
I tried to create a procedure to get around this with the following interface:
SUBROUTINE MOLD(X, Y)
IMPLICIT NONE
INTEGER, ALLOCATABLE, INTENT(INOUT) :: X(..)
CLASS(*), ALLOCATABLE, INTENT(IN) :: Y(..)
! retrieve the bounds of Y, then use SELECT RANK to allocate X
! for each rank scenario.
END SUBROUTINE MOLD
But then it fails due to the restriction that the actual argument Y needs to be unlimited polymorphic, which really defeats the flexibility and purpose of the whole thing. Again, I suspect that this restriction is not necessary when INTENT(IN) is used for Y (I understand why it is necessary in other cases), but I could be wrong.
So, the whole thing is not a big deal - it's just a bit frustrating some convenient syntax/features are 'almost within reach' but not available.
Steve_Lionel
Fortran 202X introduces a BOUNDS attribute where you can say something like BOUNDS(SHAPE(X)) in a type declaration statement, but at present it can't be used in ALLOCATE.  It seems to me that the better solution is to not require MOLD= to be type-compatible. This would require defining a new term, such as mold-expr, and saying that if mold-expr appears, the bounds are taken from it and not source-expr. (The standard prohibits specifying both SOURCE= and MOLD=, so that should be relaxed. I will suggest this for a future revision "202Y" - it is too late for 202X.
But I think you COULD do something like the following in 202X, albeit clunkily:
integer, allocatable :: x(:)
real, allocatable :: y(:)
allocate (y(3))
block
real, bounds(shape(y)) :: z
allocate (x, mold=z)
end block
Steve_Lionel
PROGRAM P
IMPLICIT NONE
END PROGRAM P
OP1
New Contributor III
Thanks Steve for your answers - always appreciated.
For this last example you provided ... will it work when X (and Y) have a rank greater than 1?
I think your suggestion to relax the constraint on MOLD= was excellent by the way.
Steve_Lionel
Yes, it will work for any rank. I had not remembered this being added and noticed it when studying the Committee Draft (22-007). With this, the change in MOLD is not needed. In fact, it works better than my suggested change as this allows you to have lower bounds other than 1. See https://j3-fortran.org/doc/year/20/20-120r1.txt
OP1
New Contributor III
I am not sure I understand your comment regarding the bounds being other than 1. I can use MOLD to 'transfer' non-unit bounds from Y to X. See below:
PROGRAM P
IMPLICIT NONE
INTEGER, ALLOCATABLE :: X(:, :), Y(:, :)
ALLOCATE(Y(0: 3, -1: 5))
WRITE(*, *) LBOUND(X)
DEALLOCATE(X)
ALLOCATE(X, MOLD = Y(:, :))
END PROGRAM P
Output:
 0 -1
 1 1
Press any key to continue . . .
Which is what I expect (and rely on extensively in my codes).
Steve_Lionel
I suppose that would work, but the F202X feature is more flexible, and at this point revising MOLD does not add any capabilities.
OP1
New Contributor III
Thanks Steve - I read the proposal and the F202X enhancement proposed is very useful and would be applicable here. I suppose that this is also what @jimdempseyatthecove had in mind with his post!
