Build errors with ifort
yfort
Hi All,
After hours of googling, I decide to give up and ask the experts! I am trying to compile a fortran code using ifort on CentOS6.4.
I have installed all the pre-requisites for intel fortan.
Following is the error I am getting:
make -f makefile
ifort -o ./p2s2 -O2 -xW -static -traceback p2s2.o read_spray_data.o sector.o beam.o cylin.o mktrac.o spray_wall.o in_cylin.o wall_evapo.o part.o idle.o drop_evapo.o point_info.o dia_distri.o char_sub.o sector_incylin.o user_func2.o xy-sec_info.o r_info.o gross_evapo.o
ifort: command line remark #10279: option '-xW' is deprecated and will be removed in a future release. See '-help deprecated'
ld: skipping incompatible /usr/lib/gcc/x86_64-redhat-linux/4.4.7/../../..//libm.a when searching for -lm
ld: skipping incompatible /usr/lib/libm.a when searching for -lm
Please let me know how to resolve this issue. I am new to using linux systems, any help is greatly appriciated, I looked at other threads but didn't get how to change the environment variables.
which ifort
/opt/intel/composer_xe_2013.5.192/bin/intel64/ifort
Thanks in advance!!
mecej4
The commands issued by make show none for compilation and one command for linking, which failed because there is an apparent mismatch between 32-bit and 64-bit objects and libraries.
How were the *.o files compiled? All using Intel Fortran? Some mix of Gcc/GFortran and Intel Fortran? Were they compiled for 32-bit or 64-bit?
Did you use the command environment spawned by running ". /opt/intel/composer_xe_2013.5.192/bin/ifortvars.sh ia32"?
yfort
Thank you for responding!
How were the *.o files compiled? All using Intel Fortran? - Yes all were complied by Intel Fortran composerxe2011
Were they compiled for 32-bit or 64-bit? - Yes they were complied on 64bit version
I used -> source /opt/intel/composer_xe_2013.5.192/bin/compilervars.sh intel64
mecej4
Thanks. It would help if you could display the value of LD_LIBRARY_PATH (type "echo $LD_LIBRARY_PATH" in the IFort shell).
yfort
Hi Mecej4, thanks a lot!
These are the runtime lib for 2011 version
/lib/composerxe-2011/intel64
TimP
Among the problems would be that a basic CentOS6 installation of g++ would not include the libraries required by your -static option.  If you can build without -static but still want to build with -static, you will need to find corresponding 64-bit .a libraries.
An intermediate choice would be -static-intel, which will choose the static libraries provided with ifort.  Then you could try -static-libgcc which would require .a versions of files which come with g++,
yfort
Yup, that was the exact problem thanks all for your help.
