Build failed
仁义_许_
ifort19
xcode10
mac10.14
I have chose ifort19 in build rules   but still
:-1: no rule to process file '/Users/shrine-Mac/Desktop/Test5/Test5/12.f90' of type 'sourcecode.fortran.f90' for architecture 'x86_64' (in target 'Test5')
Juergen_R_R
Valued Contributor II
Looking at this page: https://software.intel.com/en-us/articles/performance-tools-for-software-developers-compatibility-of-intel-compiler-for-mac-os-x-and-xcode
This has not (yet) been updated for Darwin 10.14 or Xcode 10. Maybe there is a general problem with Xcode, this I don't know. I only use the command line.
Juergen_R_R
this reads more like an error message from a Makefile than a compiler error message. You didn't pose any question but I assume you want to know why your code doesn't compile, but we need definitely more information. I also upgraded to Darwin 18.0 (Mojave) yesterday, and the Intel compiler (in the shell) still works.
Cheers,
       Jürgen
仁义_许_
CodeSign /Users/**/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Products/Debug/Test5 (in target: Test5)
    cd /Users/**/Desktop/Test5
    export CODESIGN_ALLOCATE=/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/codesign_allocate
Signing Identity:     "Mac Developer: *********@hotmail.com (RH573QJXT5)"
    /usr/bin/codesign --force --sign B468599B0D896175007526FD8E23488863D11557 --entitlements /Users/s**/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Intermediates.noindex/Test5.build/Debug/Test5.build/Test5.xcent --timestamp=none /Users/shrine-Mac/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Products/Debug/Test5
Users/shrine-Mac/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Products/Debug/Test5: No such file or directory
Command CodeSign failed with a nonzero exit code
Juergen_R_R
Sorry, but this really looks neither like a question regarding Fortran nor Intel, but just like a problem with your XCode installation. Apparently, XCode cannot find a directory it is supposed to look into. Possibly something has changed in the signing procedure for XCode development projects between XCode 9 and 10 (or between High Sierra and Mojave); maybe completely re-configure and re-build your software project?
仁义_许_
I can build it on Terminal, but can't on Xcode
warning: no rule to process file '/Users/*-Mac/Desktop/Test5/Test5/12.f90' of type 'sourcecode.fortran.f90' for architecture 'x86_64' (in target 'Test5')
warning: missing creator for mutated node: ('/Users/**-Mac/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Products/Debug/Test5') (in target 'Test5')
error: Cycle inside Test5; building could produce unreliable results.
Cycle details:
Target build order preserved because “Parallelize Build” is off
→ Target 'Test5': CodeSign /Users/**-Mac/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Products/Debug/Test5
○ Target 'Test5': CodeSign /Users/**-Mac/Library/Developer/Xcode/DerivedData/Test5-bvdubqytuvnwyugbvzboxsffzzec/Build/Products/Debug/Test5
Juergen_R_R
