29657 Discussions
Build target executable for Mac OS X on Linux
nntwoee
I'm using Intel Fortran on a Linux machine.
Is it possible to build a target executable to run on Mac OS X using Intel Fortran for Linux? If so, what compiler option would I need to use? I have tried running a Linux executable on Mac OS but without any success.
Thank you for any information you may have.
nn
mecej4
The Intel Fortran compilers for Linux do not do cross-compilation, whether for Windows or OSX -- or any OS other than Linux. Therefore, there are no no corresponding compiler options.
Sometimes, an object compiled on Linux happens to work on FreeBSD, but that may be chalked up to coincidence and common ancestry.
You could look at the possibility that some sort of virtual machine is available.
