Building DLLs from the command line
michael_green
Hi All,
I found it fairly straighforward to build a whole set of DLLs from a command script under IVF10. The main thing was to activate this line:
        call "C:\Program Files\Intel\Compiler\Fortran\10.0.025\IA32\Bin\ifortvars.bat"
which, among other things, defined ifort.
What's the equivalent in IVF Composer 2013 XE? It's obviously completely different - C:\Program Files (x86)\Intel\Composer XE 2013\Bin\ifortvars.bat makes no mention of ifort.
Any help or insights greatly appreciated.
Many thanks
Mike
Lorri_M_Intel
What happened when you invoked that bat file?  It sets up PATH, LIBRARY and INCLUDE so that the command "ifort" can be found.
            --Lorri
Martyn_C_Intel
Even simpler is to open a command window from the Start menu that already has the environment set up. Go to
All Programs / Intel Parallel Studio XE 2013 / Command Prompt / Parallel Studio XE with Intel Compiler XE v14.0 / IA-32 Visual Studio 2010 mode
(You might have different Visual Studio and compiler versions, and possibly Composer instead of Parallel Studio).
michael_green
Hi Guys,
Thanks for replies.
I would prefer to run the job in a command script, but it won't run. I have distilled the problem down to the fact that when ifortvars.bat exits, it exists everything, including the batch script in which the call to run it was embedded, so I can't do anything else. The following illustrates:
cd "C:\Program Files (x86)\Intel\Composer XE 2013\Bin"
ifortvars.bat ia32
echo Successful completion
I never see "Successful completion". What am I doing wrong?
Many thanks
Mike
Use "call ifortvars.bat ia32". I would also recommend against changing to the compiler folder..instead put the path in the command. Use %ifort_compiler14% to find it.
