29653 Discussions
Built .lib by a Visual Studio project
cnr3
Im a beginner and your help in this is appreciated.
I would like to build a static library from an existing Visual Studio project (.vfproj) using IDE (Windows OS). I know how to build a .lib from a Fortran source code. But in this case, my VS project (.vfproj) got many source files. Can I make a single .lib from the VS project?
Thank you
DavidWhite
Valued Contributor II
Quoting - cnr3
Thank you
All projects, whether to create an .exe, .lib or .dll, can have multiple source files. From the Solution Explorer, just add the required Source Files in the Source section.
