Bus error occurred
jungwukh
I could run my fortran compiled executable file before, and did not use the code for a while (2-3 month).
I tried to run it today, and met an error:
forrtl: severe (180): SIGBUS, bus error occurred
I guess this is an osx system wide problem because I could use the same executable file before.
Anyone knows a solution?
Thank you for your help in advance.
Jung
TimP
There's a paper posted at the top of this forum on this subject. Did you look? Perhaps you forgot your stack limit settings.
