C# calling Fortran Subroutine
Edward_R_1
Where is the documentation showing steps required to call a Fortran Subroutine from C#.
I am trying to import the Fortran Subroutine as follows:
        [DllImport ("WDSys.FortranCode.dll", CharSet = CharSet.Ansi, CallingConvention = CallingConvention.Cdecl)]         private static extern void WDECONMATSOLV (ref int numRows, [In,Out] ref double[] matrixA, [In,Out] ref double[,] vectorB);
the start of the Fortran Subroutine is:
      Subroutine WDECONMATSOLV(n, a, b)
c     DEC$ATTRIBUTES DLLEXPORT::WDECONMATSOLV
       parameter (MNROW=30, MNCOL=15)
c
       double precision
      +a(MNROW,MNCOL) , b(MNROW)      , fact1         ,
If someone could tell me where the documentation is. That would help.  If the documentation isn't available how do you figure it out?
TimP
You should consult the documentation on Fortran iso_c_binding, if C compatibility could do the job for you. Excellent stuff is on the web as well as in the ifort documentation. There has been some specific C# interface documentation in this forum as well as in the ifort help file.
another possible clue: much important on-line C# documentation is found under .Net rather than under C#.
