29313 Discussions
C dll called from Fortran dll called from VB
Kipling__Michael
I have successfully called a C routine in a dll from Fortran and a Fortran routine in a dll called from VB many times.  This is the first time I've tried using VB to call Fortran to call C.
The simple test routines below try to pass an integer from a Fortran routine called by VB to a C routine.
The value being passed = 12, but when it reaches the C routine, the value = 1239536.
Suggestions?
VB 2010 code:
   Declare Sub TEST_FTN Lib "LHM_Fsrc.dll" ()
   Call TEST_FTN()
FTN code:
  SUBROUTINE TEST_FTN()
  !DEC$ ATTRIBUTES DLLEXPORT, STDCALL :: TEST_FTN
  !DEC$ ATTRIBUTES ALIAS:'TEST_FTN' :: TEST_FTN
  IMPLICIT NONE
  INTERFACE
     SUBROUTINE Test_Int(i1)
        !DEC$ ATTRIBUTES DLLIMPORT :: Test_Int
        !DEC$ ATTRIBUTES DECORATE, ALIAS:'Test_Int' :: Test_Int
        INTEGER :: i1
     END SUBROUTINE Test_Int
  END INTERFACE
  INTEGER :: i1
  i1 = 12
  CALL Test_Int(i1)
  RETURN
  END SUBROUTINE TEST_FTN
C code:
  __declspec(dllexport) void Test_Int(long i1);
     long i2;
     i2 = i1;
Regards, Mike
You've told C that i1 is being passed by value, but Fortran thinks it is by refrerence. You could fix this by any of the following (in my decreasing order of preference):
1. Change the Fortran declaration of Test_Int to use the C interoperability features and the VALUE attribute:
 INTERFACE
     SUBROUTINE Test_Int(i1)  BIND(C,NAME="Test_Int")
        INTEGER, VALUE :: i1
  END INTERFACE
2. Add the following directive to the interface body:
!DEC$ ATTRIBUTES VALUE :: i1
I want to point out that the VALUE attribute in 1 above, if you didn't have BIND(C), is not equivalent to ATTRIBUTES VALUE. With BIND(C), it is - at least in this case.
3. Change the C code to accept the argument by reference (*i1 in the prototype) and dereference it in the code.
Kipling__Michael
Hi Steve,
Following your #1 preference works for me.
How would you change the following Fortran code which passes a character string to a C routine, or would you?
 Fortran code:
   SUBROUTINE TEST_FTN(choice, fname_)
   !DEC$ ATTRIBUTES REFERENCE :: fname_
   IMPLICIT NONE
   INTERFACE
      SUBROUTINE C_Routine(iChoice, FileName)
         !DEC$ ATTRIBUTES DLLIMPORT :: C_Routine
         !DEC$ ATTRIBUTES DECORATE, ALIAS:'C_Routine' :: C_Routine
         INTEGER, VALUE     :: iChoice
         CHARACTER(LEN=256) :: FileName
         !DEC$ ATTRIBUTES REFERENCE :: FileName
      END SUBROUTINE C_Routine
   END INTERFACE
   !Type call list variables
   INTEGER,            INTENT(IN)  :: choice
   CHARACTER(LEN=256), INTENT(IN)  :: fname_
   ! Type local variables
   CHARACTER(LEN=256) :: fname
   INTEGER            :: i
   fname = ' '
   fname(1:255) = fname_(1:255)
   i = LEN_TRIM(fname)
   fname(i+1:i+1) = CHAR(0)
   CALL C_Routine(choice, fname)
   RETURN
 C code:
   __declspec(dllimport) void C_Routine (int iChoice, char *FileName);
 void C_Routine(int iChoice, char *FileName)
Regards, Mike
  INTERFACE
      SUBROUTINE C_Routine(iChoice, FileName) BIND(C,NAME="C_Routine")
         USE, INTRINSIC :: ISO_C_BINDING
         INTEGER(C_INT), VALUE     :: iChoice
         CHARACTER, DIMENSION(*) :: FileName
   END INTERFACE
The standard makes an exception in this case for the rule about passing a scalar to an array.
Kipling__Michael
I'll need to study that a bit.
Thanks Steve
SergeyKostrov
Valued Contributor II
>>...I have successfully called a C routine in a dll from Fortran and a Fortran routine in a dll called from VB many times... Hi Mike, I wonder if you will be able to upload small Visual Studio project? I think it iwll be a very valuable contribution on the Fortran forum!
Kipling__Michael
Yes, I'll build one and post it Sergey
