I have a funtion in 'C'. I want to call this funtion from fortran. this function contains 2 structures paseed by pointer. How do i do this in fortran.
Ex:
struct a
int x;
float y;
struct b
int p;
float q;
In c:
fun(*a,*b);
How do I call this from fortran. Here a is the input structure and b is output structure.
i am able to fill the structures in fortran but it is unable to hold the data.
Ho do i call fun(*a,*b) in fortran?
Please explain me..
Ex:
struct a
int x;
float y;
struct b
int p;
float q;
In c:
fun(*a,*b);
Please explain me..
Please refer to our compiler document on section: "intel Fortran/C Mixed-Language Program" for details.
For your problem specifically, there's one example on how to interoperate user defined structure from the compiler user guide.
Interoperability of Derived Types
For a derived type to be interoperable with C, you must specify the BIND(C) attribute:
TYPE, BIND(C) :: MYTYPE
Additionally, as shown in the examples that follow, each component must have an interoperable type and interoperable type parameters, must not be a pointer, and must not be allocatable. This allows Fortran and C types to correspond.
typedef struct {
int m, n;
float r;
} myctype
The above is interoperable with the following:
USE, INTRINSIC :: ISO_C_BINDING
TYPE, BIND(C) :: MYFTYPE
INTEGER(C_INT) :: I, J
REAL(C_FLOAT) :: S
END TYPE MYFTYPE
Example on Interoperability of Procedures:
Consider the following call to this C function:
intc_func(int x, int *y);
As shown here, the interface for the Fortran call to c_func must have x passed with the VALUE attribute, but y should not have the VALUE attribute, since it is received as a pointer:
INTERFACE
INTEGER (C_INT) FUNCTION C_FUNC(X, Y) BIND(C)
IMPLICIT NONE
INTEGER (C_INT), VALUE :: X
INTEGER (C_INT) :: Y
END FUNCTION C_FUNC
END INTERFACE
