29386 ディスカッション
-C options Internal compiler error
pat97269
ビギナー
651件の閲覧回数
Hi all,
The compiler is crashing with the following piece of code, with the options
 ifort -O2 -c -C . removing -C seems to resolve the issue
subroutine pinv(A,X)
implicit none
double complex,dimension(:,:),intent(in):: A
double complex,dimension(:,:) :: X
double complex,dimension(:,:), allocatable :: U,V
double complex,dimension(:), allocatable :: work
double precision,dimension(:), allocatable :: s,rwork
integer :: n,r,lwork,i,info
double precision :: tol
n = size(A,1)
X=A
![U,S,V] = svd(A)
lwork=5*n
allocate(work(lwork),s(n),rwork(lwork),U(n,n),V(n,n))
call zgesvd('A','A',n,n,X,n, s,U,n,V,n,work,lwork,rwork,info)
end subroutine pinv
0 件の賞賛
1 返信
Kevin_D_Intel
従業員
651件の閲覧回数
I reproduced this using the current CXE 2013 SP1 Update 2 (Version 14.0.2.144 Build 20140120) and reported it to Development (see internal tracking id below).
You can remove the -C to avoid the error (as noted) or use the alternative spelling: -check
(Internal tracking id: DPD200255045)
返信
