CMAQ 4.6
jose_velasco
Hi everybody,
I'm trying to install CMAQ 4.6 in my server with 2 Xeon processors 2GB RAM and SuSE Linux Enterprise Server 10 with Intel Fortran Compiler 9.1.041 and the GNU gcc compiler 4.1.0. Everything seems to be ok until I execute the bldit.jproc.pgf where I obtain the following error concerning to undefined references:
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(m3msg2.o): En la funcin `m3flush_':
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x19): referencia a `__kmpc_global_thread_num' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(m3msg2.o): En la funcin `m3parag_':
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x4a): referencia a `__kmpc_global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0xb8): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x195): referencia a `__kmpc_end_critical' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(m3msg2.o): En la funcin `m3prompt_':
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x1cb): referencia a `__kmpc_global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x206): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x2e0): referencia a `__kmpc_end_critical' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(m3msg2.o): En la funcin `m3mesg_':
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x36b): referencia a `__kmpc_global_thread_num' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(m3msg2.o): En la funcin `m3msg2_':
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x3e9): referencia a `__kmpc_global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x465): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/m3msg2.F:(.text+0x4df): referencia a `__kmpc_end_critical' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(shut3.o): En la funcin `shut3_':
/env/proj/coats/ioapi_3/ioapi/shut3.F:(.text+0x17): referencia a `__kmpc_global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/shut3.F:(.text+0x45): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/shut3.F:(.text+0x1e5): referencia a `__kmpc_end_critical' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(chkfil3.o): En la funcin `chkfil3_':
/env/proj/coats/ioapi_3/ioapi/chkfil3.f:(.text+0x25): referencia a `__kmpc_global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/chkfil3.f:(.text+0x3e): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/chkfil3.f:(.text+0x2785): referencia a `__kmpc_end_critical' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(init3.o): En la funcin `init3_':
/env/proj/coats/ioapi_3/ioapi/init3.F:(.text+0x29): referencia a `__kmpc_global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/init3.F:(.text+0x7f): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/init3.F:(.text+0x13d): referencia a `__kmpc_end_critical' sin definir
/project/air5/sjr/CMAS4.6/rel/lib/ioapi_3/Linux2_ia64ifort/libioapi.a(rdvars.o): En la funcin `rdvars_':
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0x3f): referencia a `__kmpc _global_thread_num' sin definir
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0xad): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0x116): referencia a `__kmpc_end_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0x391): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0x3ed): referencia a `__kmpc_end_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0x720): referencia a `__kmpc_critical' sin definir
/env/proj/coats/ioapi_3/ioapi/rdvars.F:(.text+0x7ea): referencia a `__kmpc_end_critical' sin definir
I've installed netCDF 3.6.1 and IOAPI 3. Anyone can help me?
Thanks in advance,
Jose Antonio Velasco
