CVF RANDOM_NUMBER converges to 1
bradlepc
We're seeing strange behavior using CVF 6.6C in which the RANDOM_NUMBER function eventually converges to a number very close to 1. The problem appears to go away if RANDOM_SEED is called at the beginning of the program. However, I find nothing in the f90 standard that says this is a requirement, so I think the "fix" may just be fortuitous. Google turns up a few other mentions of this behavior, but no answers. Comments?
Pete
bradlepc
Are you getting a random distribution? Any thoughts on what could so precisely step on the random seed through two different programs and two versions of the compiler? Also, just a reminder that we have to have /threads and /libs:dll for the behavior to occur which sounds like a clue.
Just to keep context, this is part of a larger stability problem that we're trying to resolve on Windows. I know it could well be in the code, and all the usual "it runs on they other guy's platform" data points apply. I'm suspicious of some kind of C library mismatch effect, but not sure what RANDOM_NUMBER does under the hood.
Pete
I know that the implementation has special code when /threads is used so that it synchronizes access to the seed. I'll have to study this more. I didn't ask for more than a few numbers, but it looked to me that, once the call to MPI_INIT was done, that RANDOM_NUMBER behaved normally. It might do something different in an application actually making more MPI calls.
This will take a while, but I am not going to drop it... Please file an Intel Premier Support request on this and ask that it be assigned to Steve Lionel. Thanks.
jimdempseyatthecove
Pete,
In the IVF documentaton under SEED you will see the caution
"This routine is not thread-safe"
There is no similar caution under RANDOM_NUMBER (or RANDOM_SEED).
Therefore it is unknown if RANDOM_NUMBER is thread-safe. I would suspect if you cannot set the seed then it is questionable if RANDOM_NUMBER is thread-safe. It may work thread-safe in some implimentations and may not in others
Additionaly, it is ambiguous as what you would expect from multiple threads calling on RANDOM_NUMBER. i.e.
Do all threads use a commonglobal seed pair with the call to RANDOM_NUMBER being interlocked properly?
or
Does each thread use a thread-dependent global seed pair with the call to RANDOM_NUMBER insensitive to simulteaneous access?
Due to the lack of documentation regarding thread-safe and the ambiguity listed above. It would be wise for you to construct a subroutine containing critical section that uses RANDOM_SEED in a manner that produces the desired results (all threads share the seeds or all threads use independent seeds).
Jim Dempsey
bradlepc
Jim,
Thanks. As I tried to make clear before, there is only one FORTRAN thread of execution in the process.
Steve, I'll put in a Premier as requested. Thanks,
Pete
