29648 Discussions
CVF to IVF conversion & passing strings
erik_warren
I am converting a Fortran dll created with cvf 6.6 to ivf 10.0.
This dll is called from VB.NET.
In VB.NET I pass the string byval followed immediately by the length of the stringpassed byref. This arrangement works fine with the fortran dll compiled with cvf or with ivf when I set the iface:cvf compiler option.
What would I change Fortran wise and VB.NET wise in order to not use the iface:cvf compiler option?
I tried just passing the strings byref with no string lengths and this "seems" to work but when I run my vb code in debug mode every time a fortran call returns I get a PInvokeStackImbalance error.
Debugging from the Fortran side goes without a hitch.
Each sub exposed in my Fortran dll uses:
!DEC$ ATTRIBUTES STDCALL, REFERENCE, DLLEXPORT ::
Do I need to drop the STDCALL?
Erik
Keep the STDCALL and add MIXED_STR_LEN_ARG to the list of attributes.
