Call Fortran from C
lxh37
I am trying to learn how to call Fortran from C, I am able to create .so file from C and call it from Ruby On Rails,
the C code is:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
long add(long maxn, double delta, double conf, char *errMsg)
        long ERR_MSG_LENGTH, answer;
        unsigned i;
        char * iarr;
       iarr = "Hello!";
        answer = (long) (maxn+delta+conf);
        for (i=0; ((char) iarr) != '\0'; ++i) errMsg = (char) iarr;
        errMsg =  '\0';
        return answer;
but when I tried to call Fortran add function from C, I have trouble:
add.c
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
extern addsize(long maxn, double delta, double conf, long * sum);
        unsigned i;
        char * iarr;
        iarr = "Hello!";
        addsize(maxn, delta, conf, &answer);
        errMsg =  '\0';
        return answer;
addsize.f90:
subroutine addsize( maxn, delta, conf, sum ) bind(c, name='addsize')
use, intrinsic :: iso_c_binding
!use program_constants
implicit none
real(C_LONG), intent(in) :: maxn
real (C_DOUBLE), intent(in) :: delta, conf
real(C_LONG), intent(out) :: sum
sum = maxn + delta + conf;
end subroutine addsize
I compile addsize.f90 as below:
/opt/intel/bin/ifort -c addsize.f90
then compile add.c
gcc -c -shared -fPIC add.c
then create add.so
gcc -shared -fPIC *.o -o add.so
Somehow I couldn't get it to work, is anything wrong in the code? Thanks!
Liz
FortranFan
lxh37 wrote:
Well, when I comment out call to Fortran, c code works fine and c code is so simple...
Must something wrong in the interface between c and Fortran.
Liz
@Liz,
As Steve said, it would appear the code you have posted should work, however it is spread across several messages and it's unclear if there are any differences between what you show here and in your actual system which could be causing the problem.
So why don't we try something different?  Listed below is a somewhat simplified version of code for what you are trying to do that tries to use standard Fortran and C.  It works on my system and gives the output shown below.  Can you take this as-is and build execute on your system without any code changes and see what output you get?  Post here if your output is different.  This might help you figure out what is going on.
module m
   use, intrinsic :: iso_c_binding, only : c_char, c_null_char, c_long, c_double
   implicit none
   private
   public :: addsize
contains
   function addsize( maxn, delta, conf, msgLen, Msg ) result( answer ) bind(c, name='addsize')
      !.. argument list
      integer(c_long), value, intent(in)          :: maxn
      real(c_double), value, intent(in)           :: delta
      real(c_double), value, intent(in)           :: conf
      integer(c_long), value, intent(in)          :: msgLen
      character(kind=c_char,len=1), intent(inout) :: Msg(msgLen)
      !.. function result
      integer(c_long) :: answer
      !.. local variables
      integer :: i
      integer(c_long) :: LenMsg
      character(kind=c_char,len=:), allocatable :: errmsg
      !.. Message
      errmsg = "hello"
      LenMsg = min( msgLen-1, len_trim(errmsg) )
      forall (i=1:LenMsg)
         Msg(i) = errmsg(i:i)
      end forall
      !.. Append C null char
      Msg(LenMsg+1) = c_null_char
      answer = int( maxn + delta + conf ) ! the sample size
      return
   end function addsize
end module m
#include <stdio.h>
#include <string.h>
// function prototypes
extern long addsize(long maxn, double delta, double conf, long msgLen, char *Msg);
#define ERR_MSG_LENGTH 70
int main()
   long result, maxn;
   double delta, conf;
   char errMsg[ERR_MSG_LENGTH];
   maxn = 1000;
   delta = 3.2;
   conf = 6.8;
   strncpy(errMsg, "There!", (size_t)ERR_MSG_LENGTH);
   printf("errMsg before calling Fortran function addsize: %s\n", errMsg);
   result = addsize(maxn, delta, conf, (long)ERR_MSG_LENGTH, errMsg);
   printf("result=%ld\n", result);
   printf("errMsg after function call: %s\n", errMsg);
   return 0;
errMsg before calling Fortran function addsize: There!
result=1010
errMsg after function call: hello
Press any key to continue . . .
By the way, you have mixed-mode arithmetic in your Fortran code computing answer that adds an integer with two floating point variables and then casts back to an integer - is this really what you intended?  This can cause unexpected behavior unless one is very careful.
P.S.>  Are you at Penn State?  Go Nittany Lions!
lxh37
Liz
lxh37
I think I find the issue, when pass int * errMsg to Fortran function, inside Fortran function, errmsg can't be
shorter than the length of errMsg (guess if short, some elements are undefined), will cause crash when returned to C.
Liz
FortranFan
Liz
@Liz,
module m
   implicit none
   private
   public :: addsize
contains
      !.. argument list
      !.. function result
      !.. local variables
      integer :: i
      !.. Message
      errmsg = "hello"
      forall (i=1:LenMsg)
      end forall
      return
end module m
#include <stdio.h>
#include <string.h>
int main()
   long result, maxn;
   double delta, conf;
   maxn = 1000;
   delta = 3.2;
   conf = 6.8;
   return 0;
result=1010
lxh37
Thanks! Your way of using c_char is much more elegant, appreciated very much!
I will revise my code to follow yours. It seems that I find out what the problem is and
want to try to see if I can get it working.
PS: We are Nittany Lions...
lxh37
Hi, report back. I just patch errmsg in Fortran by " " to have length msgLen-1 (69 in my example). First msgLen-1 elements of iarr will have errmsg cast to int, last element to be 0 as before, the code will not crash anymore. To get whole string, In c code, replace
        //for (i=0; ((char) iarr) != '\0'; ++i) errMsg = (char) iarr;
        //errMsg =  '\0';
 with
       for(i=0;i<ERR_MSG_LENGTH;i++) errMsg = (char) iarr;
Now it works..
Will try FortranFan's way next week.
Thanks everyone for help. I work in a Linux server without GUI, so it is pretty hard to debug...
Liz
lxh37
Hi, FortranFan:
I tried your way, still crash in Ruby On Rails. I have to do similar thing to patch errmsg "Hello!" by
empty space to make it to be length msgLen-1, then copy it to msg and add c_null_char at the end,
similar as what I did using int * (in this  example, I  assume msgLen > 7 in C, so I
don't need to handle the case when msgLen is less than 6), my addsize.f90 is below.
Not sure why I need to do this (because of Ruby On Rails platform or Linux?)
integer(c_long) function addsize( maxn, delta, conf, msgLen, msg ) result( answer ) bind(c, name='addsize')
use, intrinsic :: iso_c_binding, only: c_char, c_null_char, c_long, c_double
implicit none
real(c_double), value, intent(in) :: delta, conf
character(kind=c_char, len=1), intent(inout) :: msg(msgLen)
integer(c_long) :: i, lenMsg
character(kind=c_char, len=msgLen-1) :: errmsg
errmsg(1:6) = "Hello!"
do i = 7, msgLen-1
   errmsg(i:i) = " "
end do
do i=1,msgLen-1
    msg(i) = errmsg(i:i)
end do
msg(msgLen) =  c_null_char
answer = int( maxn + delta + conf ); ! the sample size
return
FortranFan
lxh37 wrote:
Hi, FortranFan:
I tried your way, still crash in Ruby On Rails. .. Not sure why I need to do this (because of Ruby On Rails platform or Linux?)  ..
@Liz,
First, what happens when you try out the Fortran+C code in my Message #24 as-is on your system?  If that works ok and the output matches what I show in Message #24, then you can try your modified Fortran code with the C code in Message #24.  Only if works as expected do you need to proceed to Ruby On Rails i.e., take it a step at a time.
By the way, what do you mean by, "Not sure why I need to do this (because of Ruby On Rails platform or Linux?)" - do what?
lxh37
To run from Ruby On Rails, I have to create .so file and use Ruby package Fiddle to call functions
in the library, can't call C executible from Ruby On Rails, so I use a C wrapper instead.
I have tried my original code (using int * instead in Fortran) in Windows (I used C code containing main
function, similar as yours)it runs fine  (I am sure yours will run too). , but it will crash in Ruby On Rails
(in Linux), so I tried to create this simple example to seek help what might go wrong.  As I stated, it
works now after I patch the msg string by some empty space...
Liying
lxh37
Hi, FortranFan and all:
I learn to call Fortran directly from Ruby On Rails and it works perfectly, it seems that
previous crash is caused when I have is to pass char *  from Fortran to C, then from C to
Ruby On Rails.
Thanks!
Liz
Adel_S_
thank you mr. Steve
