Call a function ?!?!
muppets
Hi everyboy,
somebody gave me following source.
program main
implicit none
real(8)
x, y, z
x = 1.5d0
y = 1.2d0
call
fkt(x,y)
print
*, x,y,z
end
program main
function
fkt(a1, a2)
implicit none
real(8)
fkt, a1, a2
fkt = a1 * a2
end function
fkt
I was very surprised when I saw
  1. that the code was compiled without errors,
  2. that there were no linker errors,
  3. that the resulting exe worked without crashes, errors or something similar.
There is a function fkt which is treated as a subroutine (via call ...) by the main program. Is this allowed in standard fortran or is it just a bug? I use Visual Studio 2003 and IVF 9.0.
Thank you in advance
muppets
Steven_L_Intel1
This is not legal Fortran, but the compiler can't tell because in the main program, there's nothing to indicate that fkt is a function. If you had called fkt in a loop, the program would have died after 8 or so iterations because this mismatch corrupts the floating point stack.
In the version of the compiler you have, it does allow, in some limited circumstances, calling a name known as a function. That has been tightened in version 9.1 so if the compiler knows it's a function, it must be referenced as a function.
