I do not know whether the problem I encountered belongs here (compiler error) or to MKL forum (call to MKL solvers), so I apologize if it does not belong here.
I am compiling the same code in VS 2010 with IPS XE 2017 Update 2 and in VS 2015 with IPS XE 2016 Update 4. I am using Debug-x64 configuration with following compiler options:
/nologo /debug:full /MP /Od /I"%MKLROOT%" /I"\include" /fixed /extend_source:132 /Qopenmp /fpscomp:general /debug-parameters:all /warn:declarations /warn:truncated_source /warn:noalignments /warn:interfaces /assume:byterecl /module:"x64\Debug\\" /object:"x64\Debug\\" /Fd"x64\Debug\vc140.pdb" /traceback /check:pointer /check:bounds /check:uninit /check:format /check:output_conversion /check:arg_temp_created /check:stack /libs:dll /threads /dbglibs /Qmkl:parallel /c
While everything is OK in IPS 2016 U4, I am getting internal compiler error in IPS 2017 U2, no matter if I use x64 or Win32 platform. The error message is:
fortcom: Fatal: There has been an internal compiler error (C0000005).
ifort: error #10298: problem during post processing of parallel object compilation
By commenting out lines of the corresponding source code file, I found out that calls to dgetrs and dgerfs, see lines 272 and 281 of the source file solver_matrix_general.for in the solution I am going to attach later, are both causing the same ICE. This is how the corresponding code snippet looks like:
subroutine solveLinearSystemGeneral ( )
integer(4) :: info
! Backup matrix A and B
call backupLinearSystemMatrixAndRHS ( )
! LU factorization - matrix A is overwritten by LU factorization
call dgetrf( nDimension, nDimension, Amat, nDimension, iPivot, info )
! Solution - matrix B of right hand sides is overwritten by solution to Amat*Xmat = Bmat
call dgetrs( 'N', nDimension, numberOfRHS, Amat, nDimension, iPivot, Bmat, nDimension, info )
! Solution evaluation (copy to its own variable)
call evaluateLinearSystemSolution ( )
! Solution refinement
call dgerfs( 'N', nDimension, numberOfRHS, AmatOrig, nDimension, Amat, nDimension,
+ iPivot, BmatOrig, nDimension, Xmat, nDimension,
+ ferr, berr, work, iWork, info )
return
end subroutine solveLinearSystemGeneral
What am I doing wrong?
An internal compiler error is always a compiler problem.
Looking at the version you're using, I believe you've run across the "debug-parameters" problem. There was a problem with how the compiler was generating debug information for some PARAMETER variables. I think it was finally resolved in 17.0U4, but you have 17.0U2, correct?
Please remove that option, and rebuild.
And, if you could, would you let us know if that resolved it?
thanks -
--Lorri
thanks -
--Lorri
Yes, I am using 17.0U2; I do not have 17.0U4.
Indeed, setting /debug-parameters:none and rebuilding helped and everything works well now.
Thank you very much for your quick solution.
Glad to hear it, thanks for letting us know!
