29649 Discussions
Calling Intel Fortran DLL from Excel VBA...
jeffreyzalc
I had been using CVF 6.6 Pro to make a Fortran dll that I call from Excel VBA. Everything worked fine.
Upon building the dll using the Intel compiler, I find that when I call it from Excel VBA the arguments are passed correctly (I write them to file immediately upon entering the Fortran routine), the Fortran code executes properly (again, I dump all variables to file just before the end of the routine). However, the code never returns from the dll. That is, if in the VBA I have Msgbox calls before and after the subroutine call for the dll, I never see the second Msgbox.
This behavior occurs even if I make a very simple dll that takes two double precision arguments, say x and y, and returns y= 2.0*x. The value of x will be received correctly in the Fortran, y will be calculated properly, but the answer and control never come back from the Fortran.
None of these problems ever occur with CVF.
Make sure that either you build the DLL with the /iface:CVF option (applied by default when you convert from a CVF project) or that you specify the STDCALL and REFERENCE attributes for the DLL routine. If you get the calling convention wrong, you can see exactly this sort of problem.
I have done several example programs of Excel calling Intel Fortran DLLs and never had a problem.
martin_erwin
First, thank's for responding,
After some hours reading manuals and doing tries and errors I suddenly ended up with a now constantly working debugger but still do not know why...
Regarding toyour question: My Excel is in german (Menues and Worksheet-Function in German, VBA is as usual in English)
Now I can debug as I want. I don't know if it is important, but now I declared all my local Variables and Constants as Public ina privatmodule where I declared the dll-Library and its functions. They have originally been on the Codetable that refers to Worksheet1. There a Togglebutton_Click-Event calls the fortranroutine.
With Breakpoints in CV-Fortran and Go-Command (F5) and Breakpoints in Excel-VBA with (F8)-Debugging I now can trace through.
Until now I just managed to exchange Integer-Variables. Real-, Double-Vars, Arrays and Strings are next goals for tomorrow. Let's see.
It still is interesting for me to understand, what went wrong and if I can correct any program-options, because now I cannot exclude that problems will arise again.
Martin
