Calling Java from Fortran using JNI
Chaitra_R_
I have a program to call Fortran from Java. The codes for func.f95, addC.c, and addJava.java are as follows:
FUNCTION  add(c, iflag) RESULT(f)
INTEGER, INTENT(IN):: c
INTEGER, INTENT(OUT):: iflag
INTEGER:: f
INTEGER:: i
i=10
f=c+i
PRINT *, f
PRINT *, iflag
END FUNCTION
#include <stdio.h>
#include "addJava.h"
extern int add(int *, int *);
JNIEXPORT jint JNICALL Java_addJava_add(JNIEnv *env,
                       jobject obj, jint c, jint iflag) {
    int result;
    printf("-- We are now in the C program CCode --\n");
    printf("c=%d, iflag=%d\n",c,iflag);
    printf("Call the FORTRAN code\n");
    result = add(&c,&iflag);
    printf("-- We have now returned back to the C program --\n");
    printf("Result = %d\n",result);
    return result;
import java.io.*;
import java.lang.*;
import com.sun.jna.Library;
import com.sun.jna.Native;
import com.sun.jna.Platform;
import com.sun.jna.ptr.IntByReference;
class addJava {
    private native int add(int element, int iflag);
    public static void main(String args[]) {
	Native.setProtected(true);
	System.out.println(System.getProperty("jna.library.path"));
	System.out.println(System.getProperty("java.library.path"));
	System.load("/home/chaitra/Research/JAVA/examples/JNI/add/add.so");
        System.out.println("-- We are in the Java program JavaCode --");
        addJava result = new addJava();
        System.out.println("Call the C code");
        int sum = result.add(10, 0);
        System.out.println("-- We are back in Java --");
        System.out.println("Result = " + sum);
        System.out.println("Exit Java");
I want to know how to call Java from Fortran i.e., Fortran -> C -> Java. I want to pass the value of variable c to a Java program that computes result=c+10 and returns the value to Fortran. How can this be done? Please help!
pbkenned1
I can't compile your C driver.  Can you please attach addJava.h?
Patrick
pbkenned1
Since I needed to modify the java code to reflex my system path, I just generated my own addJava.h, so there's no need to attach your version (I only wanted to see what your java compiler produced for the C header).
I found the easiest way to do this exercise was simply to put the C driver and Fortran function in a shared object, and then make that available for java execution.
Incidently, in the Fortran function, regarding 'INTEGER, INTENT(OUT):: iflag', iflag is modified, so I just made it INTENT(IN).
Otherwise, the compiler complains:
[U544731]$ ifort -c add-orig.f90
add-orig.f90(1): warning #6843: A dummy argument with an explicit INTENT(OUT) declaration is not given an explicit value.   [IFLAG]
[U544731]$
This now all seems to work fine, considering the above changes.
[U544731]$ export LD_LIBRARY_PATH=./:$LD_LIBRARY_PATH
[U544731]$java addJava
Call the C code
c=10, iflag=0
          20
           0
c=10, iflag=0
Result = 20
Result = 20
Exit Java
[U544731]$
Hope this helps.
Patrick
