29641 Discussions
Calling .NET assemblies from Fortran
watsopc
I'd appreciate if anyone can help with the following:
I'm using Compaq visual fortran professional edition version 6.6 to connect to a C# based .NET assembly. The .NET assembly has been given a stong name and registered for use with COM. I can use the COM object
from Excel without a problem but when I attempt to call from Fortran there is silence.
I used the module wizard to build the fortran COM wrapper.
I've attached the brief code fragments below.
Regards, Pete
