29657 Discussions
Calling VC++ functrion from a Fortran DLL
demo_360
Hello everybody,
I am working on a Mixed language Program with VC++ and a fortran DLL. My Fortran DLL needs to call back a VC++(MFC) Function to store some value.
My VC++ function was...
void StoreOrtho(float x[600], float y[600],
float heightCoef[600], float slope[600]);
I call the function this way in fortran:
Call StoreOrtho(X,Y,HEIGHT_COEF,SLOPE)
But my main problem is that I don't know how to share this function to fortran. For sure I will have to declare My function as Extern, but how and where? And in My fortran subroutine how I said to her that StoreOrtho was a VC++ function.
Hope it was clear?
Demo_360
Jugoslav_Dujic
Valued Contributor II
SUBROUTINE MyDllSub(...,StoreOrtho)
!DEC$ATTRIBUTES DLLEXPORT:: MyDllSub
INTERFACE
SUBROUTINE StoreOrtho(x,y,hC,slope)
!DEC$ATTRIBUTES C:: StoreOrtho
REAL:: x(*),y(*),hC(*),slope(*)
END SUBROUTINE
END INTERFACE
#include "StoreOrtho.h"
//Fortran & callback function declaration
typedef void (*CALLBACKPROC)(
float* x, float* y, float* hC, float* slope);
extern "C" void _declspec(dllimport) __stdcall
MyDllSub(..., CALLBACKPROC Callback);
HTH
Jugoslav
demo_360
Sorry but,
can you put some explanation around all this code, cause I'm a bit mixtup. I don't realy understand what you are doing.
Why did you write #include "StoreOrtho.h" in the C++ part. StoreOrtho function was part of a document Class call RefraDoc.
Thanks Demo_360
Jugoslav_Dujic
First, CALLBACKPROC is a typedef for (C) function of appropriate prototype. Last argument to MyDllSub is (address of) such a routine. The actual argument will be yours StoreOrtho.
On Fortran side, last argument is a routine. INTERFACE block specifies its prototype. Once passed through argument-list, it can be called as any other subroutine.
I put #include "StoreOrtho.h" to describe "whatever header file is routine StoreOrtho declared in".
However, if StoreOrtho is actually a class method (you didn't say so the first time), the things change a bit:
- In C++, the first argument to a class method is hidden this. To workaround that, you have to either a) (simpler) declare StoreOrtho as static (but note that in this case it is not instantiated per object, but only per entire class) or b) Pass this all the way round through MyDllProc arg's list back to CALL StoreOrtho from Fortran (I'm not even sure about syntax correctness of the following C++ code):
SUBROUTINE MyDllSub(...,this,StoreOrtho)
INTEGER:: this
INTERFACE
   SUBROUTINE StoreOrtho(this,x,y,hC,slope)
   INTEGER:: this
   END SUBROUTINE
END INTERFACE
Call StoreOrtho(this,X,Y,HEIGHT_COEF,SLOPE)
//callback function declaration
typedef void (*CALLBACKPROC)(RefraDoc* pObj,
//Fortran function declaration
   MyDllSub(..., RefraDoc* pObj, CALLBACKPROC Callback);
MyDllSub(...,this,StoreOrtho);
IMHO it's better to avoid passing class methods around.
- Have in mind that default calling convention in VC++ is __fastcall, which is not supported in CVF. You have to use __cdecl in StoreOrtho's declaration. (!DEC$ATTRIBUTES C corresponds to __cdecl).
Jugoslav
demo_360
Thanks Jugoslav for your help, but it was very confuse around here and what I have done with your info doesn't works. I don't know what I have done wrong, but ...
You will found in this reply some part of my original code, hope it will help you to understand the structure of my apps. Maybe it will help you to to make me understand what I have to do...
First in Refra.h the main class of my project I have the declaration of my fortran subroutine, who look like this:
extern "C" PROPAGATE_DLL (float* periode, double* deltaT,
const char* END_CONDITION, int L_END_CONDITION, int* flag_zoom, int* flag);
After that in RefraDoc.h I have the declaration of my StoreOrtho function:
void StoreOrtho(float x[600], float y[600], float heightCoef[600], float slope[600]);
And in RefraDoc.cpp is implementation:
extern "C" void CRefraDoc::StoreOrtho(float x[600], float y[600], float heightCoef[600], float slope[600])
COrthogonale *newOrtho = new COrthogonale;
newOrtho->x = x;
newOrtho->y = y;
newOrtho->heightCoef = heightCoef;
newOrtho->slope = slope;
m_aOrthoArray.Add(newOrtho);
return;
Where m_aOrthoArray was of type CObArray.
My dll subroutine (PROPAGATE_DLL) was called in a function of RefraDoc.cpp
This subroutine was looking like this...
SUBROUTINE PROPAGATE_DLL(PERIOD,DELTA_T,END_CONDITION,
ZOOMF,BWF)
!DEC$ ATTRIBUTES DLLEXPORT, ALIAS:'_PROPAGATE_DLL'::
PROPAGATE_DLL
! The place were I need to call my C++ function
Call StoreOrtho(THIS,X,Y,HEIGHT_COEF,SLOPE)
END
This dll subroutine was a big loop who was executed n time and on every loop I need to call my C++ function to store the result for every orthos.
Thanks for your Help. Hope you better understand My problem, and that you will help me understand how to do the call. If you have other suggestion about the way to do this your welcome.
Demo_360
Jugoslav_Dujic
My comments & additions are marked bold.
I assume you had dllimport and __stdcall here -- otherwise I don't know how it worked
extern "C" _declspec(dllimport) __stdcall PROPAGATE_DLL (float* periode, double* deltaT,
const char* END_CONDITION, int L_END_CONDITION, int* flag_zoom, int* flag, CRefraDoc* Doc, void* Callback);
I added void* to simplify things -- I'm really not sure how to typedef a class member in C++. The call should look like:
PROPAGATE_DLL (periode, deltaT, END_CONDITION, L_END_CONDITION, flag_zoom, flag, &YourRefraDoc, (void*)YourRefraDoc.StoreOrtho);
void __cdecl StoreOrtho(float x[600], float y[600], float heightCoef[600], float slope[600]);
Use either __cdecl or __stdcall, but don't leave it undefined -- I think if you omit it, it defaults to __fastcall.
void __cdecl CRefraDoc::StoreOrtho(float x[600], float y[600], float heightCoef[600], float slope[600])
newOrtho->x = x;
newOrtho->y = y;
return;
ZOOMF,BWF,this,StoreOrtho)
DON'T use ALIAS to cheat calling convention. CVF default is __stdcall and I matched that in C++ declaration. You were actualy faking __cdecl name decoration, which causes screwage of the stack
!DEC$ ATTRIBUTES DLLEXPORT:: PROPAGATE_DLL
INTEGER:: This
INTERFACE
SUBROUTINE StoreOrtho(THIS,X,Y,HEIGHT_COEF,SLOPE)
INTEGER:: This
REAL:: X(*),Y(*),HEIGHT_COEF(*),SLOPE(*)
END SUBROUTINE
END INTERFACE
END
demo_360
I have this error message when I compile My project...
C:CogeniProjectRefraRefraDoc.cpp(406) : error C2664: 'PROPAGATE_DLL' : cannot convert parameter 8 from 'void (float [],float [],float [],float [])' to 'void (__cdecl *)(float *,float *,float *,float *)'
typedef was like this...
typedef void (*CALLBACKPROC)(float* x, float* y,float* hc, float* slope);
And StoreOrtho was declare like this:
and implemented like that:
newOrtho->x = x;
newOrtho->y = y;
return;
Do you have an idea Why??? Cause I don't know.
demo_360
Teh fortran subroutine was declare like this:
extern "C" _declspec(dllimport) PROPAGATE_DLL (float* periode, double* deltaT,
const char* END_CONDITION, int L_END_CONDITION, int* flag_zoom, int* flag, CRefraDoc* Doc, CALLBACKPROC Callback);
Jugoslav_Dujic
Yeah, C++ is rather unforgivable about type conversions, especially pointer-to-function casts (and I admit I'm not versatile enough in C++ either to always get it right without few tries). Basically, it complains that the actual argument (StoreOrtho) passed to Fortran routine does not match CALLBACKPROC prototype. Try either:
typedef void (__cdecl *CALLBACKPROC)(float* x,
or
typedef void (__cdecl *CALLBACKPROC)(CRefraDoc* cDoc, float* x,
(perhaps * must be replaced with []).
Also, you forgot __stdcall in PROPAGATE_DLL declaration.
Jugoslav
demo_360
Hello again,
My problem was partly solve but I style have problem with the type conversion. Now my error message look like this:
C:CogeniProjectRefraRefraDoc.cpp(409) : error C2664: 'PROPAGATE_DLL' : cannot convert parameter 8 from 'void (float [],float [],float [],float [])' to 'void (__cdecl *)(float [],float [],float [],float [])'
Do you have an other try for me cause I stuck.
Jugoslav_Dujic
Do you have __cdecl specified for StoreOrtho in RefraDoc.h? Sounds as if you don't.
Don't get me wrong, but you should have a word or two with a C++ expert, which I'm definitely not. Most of my C++ programming consists of trial-and-error method :-).
demo_360
Yes I have __cdecl for StoreOrtho.
Thanks a lot for your help, I really appreciate.
I will ask to somebody else.
demo_360
Jugoslav_Dujic
OK, finally...
You can't pass a non-static class member function to a non-C++ routine. What you can do is to pass a static class member (or non-member) and let that function act as a "bridge" or "driver", i.e. which just calls non-static StoreOrtho itself.
Attached is a simple mixed fortran-C++ workspace which exhibits the technique. I hope you will be able to adapt it to your needs.
Jugoslav
unjedai
I found this thread in an attempt to solve my own, related problems to calling back to several C++ functions from a FORTRAN dll. My FORTRAN dll needs to callback several C++ functions. I'm wondering if I can pass all the C++ function pointers to FORTRAN at once and save them in global variables, so that I can call the C++ routines later as needed. That would be much easier than trying to pass the function pointers in every time, and then pass them around to other internal FORTRAN subroutines that actually need to do the callback. I don't know jack about FORTRAN, but I've figured out that I can place all the INTERFACE blocks in a module (I think) and use the USE statement inside the differenent subroutines. Now if I just knew how to save the function pointers to global variables.
Michael
Jugoslav_Dujic
See here and maybe here. Beware that it's nonstandard and that it will work only under CVF.
Jugoslav
