29486 Discussions
Calling Visual Studio from a batch file to build a DLL
mattsdad
Since Visual Studio 2005 has dropped the feature to export a Makefile, is it possible to call Visual Studio from a batch file to perform a build. (I need to make a dynamic library from a batch file.)
Yes. From the command line, type "devenv /?" to see the format of the command and the various options. For example, you might have:
devenv mysolution.sln /build Debug
to build the solution's Debug configuration.
