29641 Discussions
Calling a Fortran created DLL Function from Visual Basic
bridgeguy
I have downloaded the trial version of Intel's Visual Fortran Compiler and I am investigating the possibility of creating a DLL with Fortran and using the DLL in Visual Basic. I am using Visual Studio 2005.
I began by opening a FortranDynamic Link Library typeprojecttemplate in Visual Studio. I have modified the Subroutine toproduce atrivial Fuction that returns a value.The Fortran code is:
Function FortranDLL
! Expose subroutine FortranDLL to users of this DLL
!DEC$ ATTRIBUTES DLLEXPORT::FortranDLL
FortranDLL = 3.141
Return
end
I then added a standard Windows Application to the project. I added the following Visual Basic Declare statement to declare my test DLL and call the DLL from the Form's Click Event.
Public
Class Form1
Declare Auto Function TestDLL Lib "C:VB .NET ProjectsFotran DLLFortran DLLDebugfortran dll.dll" Alias "FortranDLL" () As Single
Private Sub Form1_Click(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Click
Dim Test As Object
Test = TestDLL
End Sub
End Class
When I run the VB code above I receive the following error message stating that the program is unable to find the EntryPoint for the DLL.
System.EntryPointNotFoundException was unhandled
Message="Unable to find an entry point named 'FortranDLL' in DLL 'C:VB .NET ProjectsFotran DLLFortran DLLDebugfortran dll.dll'."
Source="Fortran DLL"
Can you point me to information that will help me create a simple Function in the form of a DLLwith Intel's Fortran Compiler and call that Function from Visual Basic using Visual Studio 2005? If it is relatively easy to do I will purchase the Compilier for use in my programs.
Thank You.
Jim Denny
gib
New Contributor II
Quoting - johnldarby
Many thanks, Steve Lionel. I am a Java programmer faced with the need to call FORTRAN dlls from VB .NET in Visual Studio 2008. I spent many hoursobtaining a lot of bad advice before I found this excellent, concise advice.
I'll bet there's nowhere on the web where you'll get programming advice as good as what you get here. :-)
dinksy
I am trying something similar...the fortran code is
Function DLL2(x)
!DEC$ ATTRIBUTES DLLEXPORT,STDCALL,REFERENCE,ALIAS:"DLL2" :: DLL2
real x
DLL2 = x
Return
end
and the visual basic code is
Public Class Form1
Declare Auto Function DLL2 Lib "D:\Abhinav\Visual Basic Codes\Dll2\Dll2\Debug\DLL2.dll" Alias "DLL2" (ByRef x) As Single
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim Test As Single
Dim a As Single = 4.2
Test = DLL2(a)
MsgBox(Test)
End Sub
End Class
The program runs butprints 5.605194E-45. I cant figure out is that i am doing wrong. Kindly advise
anthonyrichards
New Contributor III
I put this code into a Dll:
Real*4 Function DLL2(x)
!DEC$ ATTRIBUTES DLLEXPORT,REFERENCE,ALIAS:"DLL2" :: DLL2
real*4 x
DLL2 = x
Return
end
Then I inserted some Visual Basic code into an Excel worksheet and tried it out:
Public Declare Function DLL2 Lib "P:\whateverpath\dll2_test\debug\dll2_test.dll" (A1 As Single) As Single
Public Function GetDLL2(a As Single) As Single
GetDLL2 = DLL2(a)
MsgBox (Str(a))
End Function
and I invoked GetDLL2 in a formula in a cell (e.g. '=GetDLL2(B39)' taking a value in cell B39) and it worked OK. The message box showed the value and the value turned up in the Excel cell containing the formula.
Note that I use MsgBox(Str(a)) in order to get the correct value displayed.
It even works with
as the export directive.
You need the STDCALL, otherwise you'll corrupt the stack. It may seem to work in a small test case, but will cause strange failures in a real program.
