29487 Discussions
Calling a constructor of the type containing a pointer to procedure causes an Internal compiler error
pwl_b
ifort version:12.1.0 20110811I would like to call a constructor in the following example. Is there any way to do it, apart removing the pointer from the type definition, and not causing a compiler error?code:[fortran]module class_a type :: a procedure(f_interface), pointer :: f => null() end type a abstract interface subroutine f_interface( arg ) import :: a class(a) :: arg end subroutine f_interface end interface end module class_a program test use class_a type(a) :: aa aa = a() end program test[/fortran]
pwl_b
Calling a constructor with f nullified explicitely works just fine:
  type :: a
     real :: a = 0.
  end type a
  abstract interface
       import :: a
       class(a) :: arg
  end interface
end module class_a
program test
  use class_a
  type(a) :: aa
  aa = a( f = null() )
end program test
[/fortran]
Anyway, the example in the previous post should work as well.
Thanks - I have reported this as issue DPD200174320. I found another variant that also gets the internal compiler error.
pwl_b
Can I track the status of the issue somehow?
Subscribe to this thread. I will post updates when I get them. Is this blocking you?
pwl_b
If weren't for the workaround I would complain more:-). Right now this issue is not critical to me.
This was fixed in the 13.1 compiler.
