!decs attributes c :: PRINTER
!MS$ATTRIBUTES DLLEXPORT,STDCALL,ALIAS:'PRINTER'::PRINTER
WRITE(6,'("-- FORTRAN funcion printer --")')
PRINTER=2
END
#include "stdafx.h"
#include "stdio.h"
#include "ReadValue.h"
#include "jni.h"
extern "C" __stdcall int PRINTER();
// i even try with : extern "C" __cdecl int PRINTER();
JNIEXPORT jint JNICALL Java_ReadValue_getValue(JNIEnv * env, jobject jobj)
printf("-- A ver si funciona la referencia -- ");
int result = PRINTER();
printf(" -- valor de retorno ke leyo del archivo -- ",result);
return result;
Anyone can help me?? Thanks.
i have a problem, i should be doing something terrible because i.m getting an exception from the java virtual machine. Im trying the dll to return to the java a String so im doing like follows:
wrapper:
JNIEXPORT jstring JNICALL Java_Main_get_1name(JNIEnv *env, jobject jobj, jint param)
char buf[80];// = (char*)malloc(num_chars); strcpy(buf, Getname(param +1));return js;
and the fortran:
CHARACTER(80) FUNCTION GETNAME(VALUE)
!MS$ATTRIBUTES DLLEXPORT,C,ALIAS:'_Getname'::GETNAME
INCLUDE 'COMMON.LVG'
INTEGER VALUE
WRITE(*,*) "The VALUE is ", MOL(VALUE)
GETNAME=MOL(VALUE)
END FUNCTION
and the error comes where the fortran call is located. :?
# An unexpected error has been detected by HotSpot Virtual Machine:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x02cb4c7c, pid=2804, tid=1748
# Java VM: Java HotSpot Client VM (1.5.0_06-b05 mixed mode, sharing)
# Problematic frame:
# C [mlvg.dll+0x14c7c]
# An error report file with more information is saved as hs_err_pid2804.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
Anyone could give me a clue? Thanks.
Message Edited by patuco on 02-07-2006 01:17 AM
In Intel Fortran, a function that returns a CHARACTER value has the return variable passed as a hidden first argument, as if it were a subroutine with an extra character argument. That also affects where the string lengths are.
Also, do you know for certain that Java wants to call routines using the C calling mechanism and not STDCALL?
and of course what java expect is not what fortran provides... but that is one of the purpose of the wrapper: it receives a char * from Fortran and it will transform it into an String for Java.
The point is that ive never used the type CHAR(80), is something i found looking through the help, so i do not know how can i implement a function in fortan which returns a variable which contains only characters.
subroutine GetName(name)
!DEC$ATTRIBUTES whatever
CHARACTER(*) name
name = ...
name = trim(name)//char(0)
end subroutine GetName
extern "C" Getname(char*, int)
Getname(buf, 80)
Hi everyone,
Ive been trying to copy the string in the fortran code (it is equivalent as C123TE) in the wrapper but I could accomplish it.
The wrapper calls the native as follows:
Declaration
extern "C" __declspec(dllexport) char* Getname(char *,int );//_Getname
Implementation
char *buf = (char*)malloc(80);
buf = " ";
printf("Before calling the wrapper: %s ",buf);
//char buf[80];
printf(" --C Calling the native ");
Getname(buf, param);
printf("%s ",buf);
printf("-- C Return form the native->buf: ", buf);
return env->NewStringUTF(buf);
The fortran is as follows (names of the variables are unsignificant):
Mol is an array of chars which combines signs and numbers with values like: CE23R, O89R, R4576,23R45.
SUBROUTINE GETNAME(ARRAKY, VALUE)
!MS$ATTRIBUTES DLLEXPORT,C,ALIAS:'_Getname'::GETNAME INCLUDE ''COMMON.LVG'
INTEGER VALUE
CHARACTER*(*) ARRAKY
WRITE(*,*) "The INPUT is ", ARRAKY
WRITE(*,*) "The FORTRAN is ", MOL (VALUE)
ARRAKY= MOL (VALUE)
ARRAKY = TRIM(ARRAKY)
WRITE(*,*) "The ARRAKI is ", ARRAKY
END SUBROUTINE GETNAME
Output:
--C -- Calling the native
The INPUT is h
The FORTRAN is C17B
The ARRAKI is C
-- C Return form the native:
As you can observed only the first character is copied. :?
I`ve tried using an auxiliar char* and using a line like :
AYU(1:10)=MOL(VALUE)(1:10)
being the string copied into AYU ok but not in one passed as parameter:
ARRAKY(1:10)=AYU(1:10)
so as in the wrapper defining a static array (buffer[80]) but getting the same results.
Do you have any idea or suggestion? Thanks.
Message Edited by patuco on 02-07-2006 01:15 AM
Message Edited by patuco on 02-07-2006 01:18 AM
So, for the given Fortran routine, the C prototype should be:
char* Getname(char* string, int value, int stringlen);
Stringlen should be 80 in this case, obviously. Also, you should append a char(0) to the Fortran string, so that it can be parsed correctly in C:
ARRAKY= TRIM(MOL(VALUE))//CHAR(0)
hi,
ive tryed your suggestions but i do not get what i am not considering,because the same behaviour is produce, i mean, the fortran code is parse:
c!MS$ATTRIBUTES REFERENCE :: ARRAKY
INTEGER VALUE
WRITE(*,*) "The FORTRAN is ", MOL(VALUE)
being call in the way:
extern
"C" __declspec(dllexport) char* Getname(char * ,int ,int );//string, str_length, element
char *buf = (char*)malloc(80);buf = " ";
Getname(buf, 80,80);printf("%s",buf);
//strcpy(buf, Getname(param,aux)); return env->NewStringUTF(buf);}
but the results arelike before:
The INPUT is h //???
The FORTRAN is OH
The ARRAKI is O //?????
Adding some comments to my previous subject is that i was performing some tests and getting all teh time the same result, only the first character is copied:
extern
"C" __declspec(dllexport) char* Getname(int * value, char * string, int * stringlen);//_Getname char *buf = (char*)malloc(10); Getname(¶meter, buf, &i);//parameter = i = 10SUBROUTINE GETNAME(VAL, ARRAKY)
CHARACTER (*)ARRAKY
ARRAKY="ayudaaa"
WRITE(*,*) "The INPUT is? ", ARRAKY
And another point, after leaving the fortran code the value is not saved (for the moment only one character)!!!!! I thought iwas passing the parameter by reference.
Message Edited by patuco on 02-07-2006 05:05 AM
before trying
extern "C" __declspec(dllexport) char* Getname(int *molecule, char * string, int *stringlen);//_Getname
i tryed with
extern
"C" __declspec(dllexport) char* Getname(int molecule, char * string, int stringlen);//_Getnamebut getting the same result, on ly the first char is copied and what i found after leaving the fortran it is not actualized. Could it be the C decalaration, so instead of it i should used stdcall?
I am getting crazy.... i do not know what is going on with this char *???
By the way, thanks a lot for your help ok?
extern "C" __declspec(dllimport) void
Getname(int molecule, char* string, int stringlen);//_Getname
is paired with
subroutine Getname(molecule, string)
!DEC$ATTRIBUTES C, DLLEXPORT, ALIAS:"_Getname":: Getname
integer molecule
character(*) string
WRITE(*,*) LEN(string)
I tryed your suggestion and i get a result which makes mescare.
Output
1
he INPUT MOLECULE is? |
Using only LEN to obtain the length of the array passed is only 1 !!??
i think the parameter definition and implementation is ok, isnt it?
extern
"C" __declspec(dllimport) void Getname(int molecule, char * string, int stringlen);Implementation
int i = 15;//length of the vector int parameter = 5;//to access the 5th element in fortran char *buf = (char*)malloc(i);buf = " ";
printf("--C-- buffer: %s ",buf);
Getname(parameter, buf, i);
printf(" -- C --REturned buf: %s ", buf);
jstring jstrBuf = env->NewStringUTF(buf); return jstrBuf;by the way, why instead fo dllexport, dllimport??
i tryed another test and the same
CHARACTER (*)ARRAKY
ARRAKY="ayudaaa"
ARRAKY= TRIM(ARRAKY)//CHAR(0)
WRITE(*,*) LEN(ARRAKY)
write(*,*) "The INPUT MOLECULE is? ", ARRAKY
output:
1
The INPUT MOLECULE is? a
adding to the last comment where i explain the results obtained
i am trying another thing using de atributes value and reference, as follows:
!MS$ATTRIBUTES VALUE :: VAL
CHARACTER *48 ARRAKY
cARRAKY="ayudaaa"
cARRAKY= TRIM(ARRAKY)//CHAR(0)
now the output of the length is what i specified in the declaration !!????
and another thing is that each time i tryed to copy values im gettin an error.
eventhough defininig the buffer as :
const int i = 15;char buf;
1
The INPUT MOLECULE is? ?
Sorry, I can't spot anything wrong with the next-to-last version.
It appears that !DEC$ATTRIBUTES C also implies that strings are passed by value (!). I don't know why on Earth would anyone want to do that, but that's how it's implemented.
So, you should specify REFERENCE for the string argument, and pass the length explicitly:
SUBROUTINE GETNAME(VAL, ARRAKY, iLen)
!MS$ATTRIBUTES REFERENCE:: Arraky
INTEGER val
CHARACTER(iLen) ARRAKY
ARRAKY="ayudaaa"
Getname(int molecule, char* string, int len);
Btw, __declspec(dllimport) is needed (but can be omitted) because you're importing the symbol from another dll.
