29388 Discussions
Calling fortran function or procedure from a c main
fly_email
Hi, all
I'm new with fortran
I'm trying to migrate a HP3000 application.
My problem is to build a static or dynamic fortran library.
The main program is a c program.
I've got unresolved when linking the c main.
Example:
aff error LNK2001: symbole externe non rsolu _for_cpystr
I'm using :
Intel Fortran Compiler Integration for Microsoft Visual Studio .NET 2003, Version 9.0.2713.2003, Copyright (C) 2002-2005 Intel Corporation
The library is for the moment static.
Do i have do add lib to the c project ?
Thanks in advance.
Franck.
fly_email
Oh,
I think i've found the solution
I've had /MTd in the Additionnal Options of the command line/LibrarianProject property page ...
Is it the right solution ?
Franck.
TimP
If your project is plain C, it may be simpler to try ifort as the linking command. for_cpystr comes from one of the libraries supplied with ifort. ifort would choose the correct libraries from that group.
MT libraries are required for thread safety; if you don't use threading or OpenMP, they may not be the best choice.
