29386 Discussions
Can GPUs be used to speed up MPI computations
Anders_S_1
New Contributor III
I am running FP-heavy computations using Fortran and MPI under Windows. It is not possible to
use OpenMP. Is it possible to offload FP calculations to a GPU to get a speed up? Do GPUs offer double precision calculations?
Best regards
Anders S
Barbara_P_Intel
Here's some info to help you get started.
Three Quick, Practical Examples of OpenMP Offload to GPUs (video)
https://www.intel.com/content/www/us/en/developer/videos/three-quick-practical-examples-openmp-offload-gpus.html
Run HPC Applications on CPUs & GPUs with Xe Architecture Using Intel® C++ & Intel® Fortran Compilers with OpenMP* (video)
Run HPC Applications on CPUs & GPUs with Xe Architecture Using Intel C++ and Intel Fortran Compilers with OpenMP
Basic understanding of GPU architecture
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-gpu-optimization-guide/top/xe-arch.html
oneAPI GPU Optimization Guide
https://www.intel.com/content/www/us/en/develop/documentation/oneapi-gpu-optimization-guide/top.html
As far as a "sandbox", use Intel DevCloud for oneAPI.
Barbara_P_Intel
For a Fortran application to offload to an Intel GPU, OpenMP directives are required. MPI optimizations around offload are related to managing where a given rank offloads.
The availability of double precision FP calculations varies by the Intel GPU. For example, the GPUs targeted for gaming have single precision FP.
Anders_S_1
New Contributor III
Hi Barbara,
Thanks for your swift reply!
Which Intel GPUs offer double precision?
If I understood you right, work can be offloaded from each MPI rank using OpenMP directives. Is there any rule of thumb when offload to a GPU will result in a speedup as a function of size of the MPI task?
Is there any sample code or example on offload of a double precision workload to a GPU?
Is it possible to evaluate a simple example in a "sandbox"?
Best regards
Anders S
Barbara_P_Intel
Anders_S_1
New Contributor III
Hi Barbara,
As for the sandbox, will it be possible to evaluate offload to the MAX 1100 GPU (or similar) in the near future?
Best regards
Anders S
Barbara_P_Intel
I don't know the roadmap for DevCloud. There is a Community Forum for DevCloud questions.
