29352 Discussions
Can a private module varialbe be be assinged to threadprivate?
stydofe1
Anyone knows if a module variable with private attribute can be assigned to threadprivate in OMP? I tried this, define several such module variables as threadprivate, the compiler seems to be OK with this but the program crashes for no reason.
The PRIVATE attribute would have no effect on OpenMP - all it does is control the visibility of the name to program units that USE the module.
jimdempseyatthecove
A "static" variable/array/user defined typein a module can be thread private
A member variable within a user defined type cannot be thread private without the encapsulating user defined type being itself thread private. If this is not your circumstance, then you have a coding error. The usual errors relating to this is failure to initialize data that ought to have been initialized. I suggest you insert some conditional compiled asserts into your code to assure that what you assume to be true is in fact true.
Jim Dempsey
