29648 Discussions
Can command line users use MSC6 with IVF?
dave_frank
I didnt get a answer last week to this question.
I currently am using CVF6 with MSC6, someone (I think) reports MSC6 is ok with IVF as long as dont try to use the IDE.
Is this true?
I did a couple of tests and it seemed to work ok, but the MSVC6 linker may choke on some of the object language the compiler puts out. It's not supported. Some of the compiler diagnostic features won't work (such as uninitialized variable checking.) If it works for you, fine, but we won't be able to help you with problems that don't occur in a supported configuration.
Since MS offers a free download of its "Visual C++.NET 2003 Toolkit", I don't really see the point of fudging this with CVF. (Unfortunately, we can't redistribute this.) But if you want to try it with CVF, the same tips apply as I posted elsewhere in the forum for use with the Toolkit.
