29657 Discussions
Can f90SQL-Lite Library work in 64-Bit Window Server?
tom_c_lin
Good Morning Everyone,
We have an application using f90SQL library to read our SQL database which is residing in a 64-bit Win server. The application was deveoped with Intel Visual Fortran compiler in .NET environment. The program works fine when it runs from Win XP or Win 2003 servers (both are 32-bit). When we moved the program into a 64-bit server and started the program from there. It returned all zeros from SQL database calls. Did any of you have the same problem? Any comments or suggestions? Thanks. Happy New Year.
Tom Lin
