29649 Discussions
Can loading Advisor, Inspector and VTune Amplifier stuff during project loading be disabled?
jirina
If I open a project in VS, it takes quite a lot of time for the project to load. I checked the disk activity in Resource Monitor and noticed that Advisor, Inspector and VTune Amplifier DLLs are being accessed. I have no idea whether they could be significantly contributing to time needed to load a project/solution (and also to memory usage by VS), but if it is the case, is there a way to disable them? I do not use them often, so this would save me time and memory.
Also, it feels like the same is happening if I am loading a C++ project, so nothing related to IPS XE.
I use VS 2010 Pro SP1 with IPS XE 2016 Update 3 on Windows 7 Pro SP1.
I don't know of a way to disable loading the DLLs.
