29653 Discussions
Can one plot TWO curves using ArrayVisualizer?
rahzan
I would like to have two line graphs plotted simultaneously onagraph sheet.
Is this possible using AV?
If yes, is there a sample I can look at?
Tim
rahzan
Someone replied to this msg but after the forum problem the replies were erased. hope you'llcatch this thread again:
Thanks for the reply.
Since I am very new to this AV thing, may I trouble you to provide the whole sample project?
I do not for example know what to put on the dialog box.
If posting is not possible maybe directemail will be possible:
I will be obliged.
Tim
metze
hi,
could you send me the answer to the above question? I use the arrVis sample with array m_A(i,j) and I get one courve. How do I get two curves?
thanks ingolf
