29413 Discussions
Can't find a break point in 2 byte language folder
우왕희_WooWangHee
Can't find a break point in 2 byte language folder In Visual fortran 11.1, 2011 & Visual Studio 2008, 2010
One of the 2 byte language is Korean
So
When I use Intel Visual Fortran, I can not use Korean Folder.
It's very Inconvenience debugging!
Many people don't know a reason for can't find a break point in Visual Fortran
Is there a way to fix this?
Can you explain in more detail what goes wrong or what doesn't work? I don't understand your description of the problem. Does the source file display in Visual Studio? Perhaps you could attach a screen shot (JPG or PNG) showing the problem.
우왕희_WooWangHee
New Project - Intel Visual Fortran Console Application
Project Name can not use Korean, Only English
Because Project Name is Folder Name
Are you using a full version of Visual Studio or the "Shell" that comes with Intel Visual Fortran?
우왕희_WooWangHee
I am using a full version of Visual Studio 2010, 2008
Thanks. I am asking one of our localization experts to look into this. Can you create a Visual C++ project with a Korean name?
우왕희_WooWangHee
Yes, I can create.
and it worked.
Ok, thanks. I'll ask the developers to look into this.
The developers have asked for screenshots showing the problem. Please take some and attach them to a reply here. Perhaps put them in a ZIP file and attach that.
우왕희_WooWangHee
Thank you for the screen shots.
The developers tell me that they cannot reproduce the problem - that they can create projects with Korean names in Korean-named folders and set breakpoints in them.
I note that you mention using Visual Studio 2010 - are you using Intel Visual Fortran Composer XE 2011 with that? Have you selected compiler version 12 in Tools > Options > Intel Fortran > Compilers? Please try all these things with just VS2010 and Intel Visual Fortran Composer XE 2011. Show me what works and what doesn't work.
